I'm trying to make automation for the greenhouse using umqtt.simple. I have a 4 channel LC Technology relay with ESP-01(2MB) on board.
I have written some code using examples from this forum (thanks for pythoncoder ) and other sites. This relay can be controlled using special 4byte commands sent by UART.
This is my main.py file. I made boot.py empty.
This program is working and I can switch 1 of 4 relays sending ON or OFF command over MQTT.
My problem is that after about 2 minutes of working relay doesn't respond correctly to my commands. For example, I send ON command and relay opens and after several seconds it closes automatically(I can't understand WHY). Another example is that after some minutes of correct work It doesn't respond to my MQTT messages at all( I saw fast blue led blink but relay didn't change the state.)
import ubinascii
import micropython
import esp
esp.osdebug(None)
import gc
gc.collect()
ssid = 'example'
password = '12345678'
mqtt_server = '192.168.0.91'
client_id = ubinascii.hexlify(machine.unique_id())
topic_sub = b'esp/relay'
topic_pub = b'esp/relay/answer'
state = b'OFF'
uart = machine.UART(0, 115200)
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(ssid, password)
while station.isconnected() == False:
pass
print('Connection successful')
print(station.ifconfig())
def sub_cb(topic, msg):
global state
print((topic, msg))
if msg == b'ON':
uart.write(bytes([0xA0, 0x01, 0x01, 0xA2]))
state = b'ON'
client.publish(topic_pub, state)
elif msg == b'OFF':
uart.write(bytes([0xA0, 0x01, 0x00, 0xA1]))
state = b'OFF'
def connect_and_subscribe():
global client_id, mqtt_server, topic_sub
client = MQTTClient(client_id, mqtt_server)
client.set_callback(sub_cb)
client.connect()
client.subscribe(topic_sub)
print('Connected to %s MQTT broker, subscribed to %s topic' % (mqtt_server, topic_sub))
return client
def restart_and_reconnect():
print('Failed to connect to MQTT broker. Reconnecting...')
time.sleep(10)
machine.reset()
client = connect_and_subscribe()
except OSError as e:
client.check_msg()
time.sleep(0.2)
P.S. I mentioned that after several minutes of work, the ESP-01 is hot, maybe this is a problem?
