External binary/lib C++
montyx
Post by montyx » Sat May 09, 2020 6:16 pm
Hey guys!
My question can be generic, but I describe my issue.
I really need a classic Bluetooth function in my ESP32 codebase. I've read in the ESP32 documentation that, the MP is built on-top of ESP-IDF.
Is there any way, to write my functionality with ESP-IDF framework, and use it from my MP codebase?
Or this should be much more better, if I could use the arduino bluetooth library of ESP32.
Is there any way to use external binaries or C++ libs?
Thanks a lot
zeilenschubser
Re: External binary/lib C++
Post by zeilenschubser » Sat May 09, 2020 10:32 pm
Have a look at
  1. how Arduino does it / Look here too
  2. The SPP-Interface of the ESP-IDF Stack:
  3. The Bluedroid Implementation in the esp-idf
Feel free to then pullrequest your module!
montyx
Post by montyx » Sun May 10, 2020 10:36 am
Have a look at
Thanks a lot for the useful links, but I was able to implement this part of my code. The only issue is that, how can I wrap it into my micropython project? I'd like to run this bluetooth based code as part of a micropython project.
My plan is to turn on/off the bluetooth connection from python on-demand. The firmware in my plans have two parts:
1. a python app, which running always, collecting data, transferring through mqtt to the server.
2. a bluetooth configuration part, which is needed on-demand, not always. It helps to configure the device with UART serial communication, that I can translate to bluetooth serial/rfcomm.
Both of these part of codes are already implemented. So I just looking for a solution, how can the python code start and stop a bluetooth service, which is implemented in arduino or EPS-IDF C++.
Post by OutoftheBOTS_ » Sun May 10, 2020 10:30 pm
Have you read this http://docs.micropython.org/en/latest/d ... dules.html
I am also trying to find Mike's github where he had written a heap of examples for all sorts of data types.
There is also this viewtopic.php?t=6786
montyx
Post by montyx » Sun May 10, 2020 11:47 pm
Thank you very much, I'm going to test it! :)
SpotlightKid
Post by SpotlightKid » Mon May 11, 2020 8:28 am
https://github.com/miketeachman/MicroPy ... examples.c
Post by OutoftheBOTS_ » Mon May 11, 2020 11:21 am
I will bookmark that :)
