SD Card, can't write from another module or async tasks.
prem111
Post by prem111 » Tue May 26, 2020 9:37 pm
Why when I mount the SD in start boot.py or main.py I can't write to a file from another module or from task async? Do I have to grant any permissions?
main.py
import os
os.mount(machine.SDCard(slot=3,width=4), "/sd")
Re: SD Card, can't write from another module or async tasks.
Post by dhylands » Tue May 26, 2020 10:38 pm
You should be able to. Make sure you're using a filename like "/sd/filename.txt" (it's the /sd part that's important, not the filename)
prem111
Post by prem111 » Wed May 27, 2020 6:31 am
Yes, I do it exactly, it works when I start from one class, but when I do mount in main.py, while open and write in async def doesn't work anymore.
prem111
Post by prem111 » Wed May 27, 2020 10:48 am
Ok sorry, my mistake. Its work fine !
