uasyncio - How detect the end task in another task.
Re: uasyncio - How detect the end task in another task.
A gotcha thanks! Yeah, it's not suuuper important. Another question - can you write a function that let's you toggle between two (or more functions) via button push? I.e. first function runs, button press, second function runs, button press, first function runs again.
There are plenty of ways to do this
Result:
Clearly foo() could call other functions if that's what you want.
toggle = False
def foo():
global toggle
if toggle:
print('toggle was True')
print('toggle was False')
toggle = not toggle
>>> foo()
toggle was False
>>> foo()
toggle was True
>>> foo()
toggle was False
Ah nice! Thanks, Pete!
Hi Pete,
Follow up to the toggle function. I'm not trying to get carried away, but this keeps popping up in my mind
Do you think it's possible to use the toggle function you showed me in the async main function to switch between two asynchronous tasks while all others keep doing their thing?
Toggle function
It would be called by switch.press_func, or double/long press alternatively
Please let me know your thoughts. I imagine that could be one way to switch between two display functions.
Toggle function
toggle = False
def foo():
global toggle
if toggle:
uasyncio.create_task(my_class.blink())
uasyncio.create_task(my_class.temp())
toggle = not toggle
async def main():
set_global_exception() # Debug aid
my_class = tempReader(led, sensor, oled, sw, enc, lcd) # Constructor might create tasks
switch = my_class.sw#Pushbutton(sw, suppress = True)
switch.press_func(foo, ()) # this is where the toggle would get called
#uasyncio.create_task(my_class.blink()) # Or you might do this
#uasyncio.create_task(my_class.temp())
uasyncio.create_task(my_class.encoder_loop(enc))
uasyncio.create_task(my_class.show())
uasyncio.create_task(my_class.show_lcd())
await my_class.cancel() # Non-terminating method
uasyncio.run(main())
finally:
uasyncio.new_event_loop() # Clear retained state
As written each time you press the switch you are creating a new task instance. I think you need to cancel the running task before creating a new one.
Ah gotcha. That makes sense. Is there a uasyncio function that lets me cancel a specific task? In this case it would just be the two in the toggle, right? A la, cancel 1 create 2, and vice versa.
Hey, thanks - found it!
I tried a simple example
However, pushing the button doesn't actually cancel blink2_task = uasyncio.create_task(blink2(led2)). What am I missing here?
If I wanted to alternate tasks, I assume they would have to be in the foo() function and cancel each other. I have tried that too, but wanted to know if they have to defined before the actual function body? I got assigned but not used errors, e.g.
As always, greatly appreciate the help
from machine import Pin, Timer, I2C
import dht
import uasyncio
import gc
from aswitch import Switch, Pushbutton
led2 = Pin(19, Pin.OUT) #green
led4 = Pin(33, Pin.OUT) #red
sw = Pin(18, Pin.IN, Pin.PULL_UP)
switch = Pushbutton(sw, suppress = True)
async def blink2(led):
led.on()
await uasyncio.sleep_ms(100)
led.off()
async def blink3(led):
led.on()
await uasyncio.sleep_ms(200)
led.off()
async def nothing():
await uasyncio.sleep_ms(2)
toggle = False
def foo():
global toggle
if toggle:
blink2_task.cancel()
toggle = not toggle
async def cancel():
await uasyncio.sleep(60)
def set_global_exception():
def handle_exception(loop, context):
import sys
sys.print_exception(context["exception"])
sys.exit()
loop = uasyncio.get_event_loop()
loop.set_exception_handler(handle_exception)
async def main():
switch.release_func(foo(), ())
#other async tasks...
await cancel() # Non-terminating method
finally:
gc.collect()
gc.threshold(gc.mem_free() // 4 + gc.mem_alloc())
toggle = False
def foo():
global toggle
if toggle:
blink3_task = uasyncio.create_task(blink3(led4))
blink3_task.cancel()
toggle = not toggle
Can I respectfully suggest you find an online course or buy a book on Python programming? You need to learn about Python scoping rules and the lifetime of variables.
The reason I declared toggle as global is that functions forget variables declared in their body when they terminate. The global declaration enables the named variable to persist.
Hey Pete, you sure can! I read up on it and figured it out with the input on the global stuff from you.
I got it to work like this:
I had to add the exception b/c otherwise it throws an attribute error.
def foo():
global toggle
global blink2_task
global blink3_task
if toggle:
print('Toggle')
try: # this is necessary b/c otherwise it throws an attribution error b/c blink3_task is a boolean before assignment
except:
pass
print('Else')
toggle = not toggle
