Build upython on stm32cube ide?
miltmobley
Post by miltmobley » Sun Jul 26, 2020 2:36 am
1. Can micropython and its firmwares be built on STM32Cube IDE using an STM32F405xx (pyboard) processor configuration?
2. Is source available for the threading firmware?
3. In general, how does your firmware differ from the standard stm32 firmware provided by STM32Cube?
Re: Build upython on stm32cube ide?
Post by jimmo » Mon Jul 27, 2020 3:22 am
If you can make the IDE run a Makefile, yes. What I'd recommend is following the steps to build the firmware outside the IDE (see https://github.com/micropython/micropyt ... /README.md) and then once that's working you can invoke it from the IDE.
If you want to build the pyboard firmware exactly, then
make BOARD=PYBV11
otherwise you can copy the ports/stm32/boards/PYBV11 directory, modify whatever you need (e.g. pin assignments) and build that instead
make BOARD=MYBOARD BOARD_DIR=path/to/MYBOARD
It's the same source, just built with a different option.
You can either do this by adding
#define MICROPY_PY_THREAD (1)
to your mpconfigboard.h
or by adding
make BOARD= .... CFLAGS_EXTRA='-DMICROPY_PY_THREAD=1'
to the make command line.
Can you explain what you mean by "standard stm32 firmware provided by STM32Cube?"
miltmobley
Post by miltmobley » Thu Jul 30, 2020 2:01 am
I meant the stm32 hal library layer, which I assumed micropython would have some variant of. But after some investigation,
it seems the micropython libs are accessing the hardware directly and not calling through a hal layer.
Thanks for your other answers.
Post by dhylands » Thu Jul 30, 2020 7:33 pm
Some of the peripherals are accessed through the HAL layer, and some are accessed directly.
