OneWireError exception
spoz
Post by spoz » Sat Aug 15, 2020 9:26 am
Hi all,
I'm using an ESP8266 with a DS18B20 temperature sensor and the OneWire library. I'm trying to handle an exception in the case where the sensor becomes disconnected during runtime.
Without any error handling if I disconnect the sensor and run:
sensor.convert_temp()
then I see:
  File "ds18x20.py", line 19, in convert_temp
  File "onewire.py", line 22, in reset
OneWireError:
If I try to catch the exception, my code looks like:
except OneWireError:
	print("Error")
Then I get:
  File "<stdin>", line 2, in <module>
NameError: name 'OneWireError' isn't defined
Looking in the onewire library, the OneWireError exception class is just a "pass". Is this the problem? What is the correct way to handle this error?
kevinkk525
Re: OneWireError exception
Post by kevinkk525 » Sat Aug 15, 2020 12:54 pm
you have to catch "onewire.OneWireError" if you import onewire at the top of the module.
Kevin Köck
spoz
Post by spoz » Sat Aug 15, 2020 1:32 pm
D'oh. Thanks so much for the reply.
