WIZnet5K use DHCP ?
water
WIZnet5K use DHCP ?
Post by water » Fri Sep 11, 2020 3:35 pm
Can I configure WIZnet5K use DHCP ?
If not, how to set the network parameter ?
I try to use
nic.ifconfig(('192.168.1.103', '255.255.255.0', '192.168.1.1', '8.8.8.8'))
(e.g. my router IP address is '192.168.1.1')
but can't not connect to internet, WIZnet5K device can't detect on router (it should be detected).
I use adafruit_wiznet5k library on CircuitPython success to connect to internet, so the hardware is correct.
https://circuitpython.readthedocs.io/pr ... t/api.html
How should I configure WIZNET5K correctly on MicroPython ?
Stevo52
Re: WIZnet5K use DHCP ?
Post by Stevo52 » Thu Sep 24, 2020 3:44 am
You haven't shown how you set up the WIZnet5k device?
This section of Micropython documentation might be worth reading, to help you figure it out...
http://docs.micropython.org/en/latest/l ... NET5K.html
