uasyncio - sched module, long delay events.
AndreaC
Post by AndreaC » Thu Oct 08, 2020 11:16 am
struggling days to understand why a schedule like this (running on a pyboardv1.1 fw:1.13):
async def mycoro():
    print('hello world')
    await asyncio.sleep(0)
async def main():
    asyncio.create_task(schedule(mycoro, hrs=12))
    loop.create_task(main())
    loop.run_forever()
except KeyboardInterrupt:
    pass
finally:
    asyncio.new_event_loop()  # Clear retained state
instead of everyday at 12am launches mycoro approximately every 16mins and 40secs.
Eventually today, looking at schedule coro definition I discovered the clause:
maxt = 1000 # uasyncio can't handle arbitrarily long delays
Onestly I can't figure out how to achive my goal? should the schedule coro return instead of launch the passed function just after 1000secs?
I am missing something?
Hope I explained myself clearly.
Regards
AndreaC
Re: uasyncio - sched module, long delay events.
Post by AndreaC » Thu Oct 08, 2020 3:19 pm
async def mycoro():
async def main():
    loop.run_forever()
    pass
finally:
Regards
I have apparently by-passed the problem by modifying the schedule function in order to wait until its time to launch the func, but I am still not sure if my approach is correct.
async def schedule(func, *args, times=None, **kwargs):
    fcron = cron(**kwargs)
    while times is None or times > 0:
        tw = fcron(int(time()))  # Time to wait (s)
        while tw > 0:  # While there is still time to wait
            # *** Added a new variable here tw_***
            tw_ = min(tw, maxt)
            await asyncio.sleep(tw_)
            tw -= tw_
        res = launch(func, args)
        if times is not None:
            times -= 1
        await asyncio.sleep_ms(1200)  # ensure we're into next second
    return res
Post by pythoncoder » Fri Oct 09, 2020 10:19 am
See my scheduling module which allows uasyncio tasks to be scheduled over very long periods.
As a general point there is normally no point in using micropython.schedule() with uasyncio. Its purpose is to be called from interrupt service routines.
The uasyncio way is for a coroutine to pause for a period, then trigger the task with asyncio.create_task(). However the way that uasyncio implements sleep() and sleep_ms() means there is an upper limit to the delay. My schedule module overcomes this limitation.
AndreaC
Post by AndreaC » Fri Oct 09, 2020 12:24 pm
Thank you Peter, but the point is that I am indeed talking about your schedule module not the micropython.schedule().
# sched.py
# Copyright (c) 2020 Peter Hinch
# Released under the MIT License (MIT) - see LICENSE file
import uasyncio as asyncio
from sched.primitives import launch
from time import time
from sched.cron import cron
            tw = min(tw, maxt)
            await asyncio.sleep(tw)
            tw -= maxt
            times -= 1
    return res
For what I can see, if the value returned by the cron object
is greater than 1000 as in my case, the schedule coro according to
	tw = min(tw, maxt)
        tw -= maxt
will launches de func at the 1000th second, so I can not figure out how it can deal with long delays?
Post by pythoncoder » Sat Oct 10, 2020 9:26 am
Ah, sorry about the misunderstanding.
You have indeed found a howler of a bug in my code. :(
[EDIT]
I have pushed an update. This is my fix:
            await asyncio.sleep(min(tw, maxt))  # Never wait longer than maxt
            tw -= maxt
            times -= 1
    return res
I have modified your test script to make it more compliant with the V3 way of doing things (not that this has anything to do with the bug).
from time import localtime
from sched.sched import schedule
async def mycoro():
    yr, mo, md, h, m, s, wd = localtime()[:7]  # Provide confirmation of when it ran
    fst = 'Callback {:02d}:{:02d}:{:02d} on {:02d}/{:02d}/{:02d}'
    print(fst.format(h, m, s, md, mo, yr))
async def main():
    asyncio.create_task(schedule(mycoro, hrs=11))
        await asyncio.sleep(100)  # Keep the scheduler running forever
    asyncio.run(main())  # This has superseded the event loop stuff
finally:
AndreaC
Post by AndreaC » Sat Oct 10, 2020 11:59 am
Thanks Peter, especially for the valuable advice on my code. I would like to congratulate you for the amazing work you did with the uasyncio tutorial. Since I discovered the existence of uasyncio I completely rewrote the code of my project which was previously based on threads. Now I have no more problems regarding the heap fragmentation. :D
