asyncio : cancelling gathered tasks
jpbihin
Post by jpbihin » Sat Oct 24, 2020 5:14 pm
As an exercise, I set myself this goal : cancelling gathered tasks.
I'm working with asyncio V3 and a ESP32
import uasyncio as asyncio
from pushbutton import Pushbutton
# pushbutton is Kevin Köck's module
p = Pin(26, Pin.IN, Pin.PULL_UP)
pb = Pushbutton(p)
async def fn_1() :
    while True :
        print("fn_1 every 3 s")
        print(time.time())
        await asyncio.sleep(4)
async def fn_2() :
    while True :
        print("fn_2 every 6s")
        print(time.time())
        await asyncio.sleep(6)
async def foo():
    tasks = (fn_1(), fn_2())
    await asyncio.gather(*tasks)
    print("in foo")
async def cancel_foo():
    print("ready to cancel")
    foo_task.cancel()
    await asyncio.sleep(0)
    print ("game over")
async def main() :
    global foo_task
    pb.press_func(cancel_foo)
    foo_task = asyncio.create_task(foo())
    while True :
        await asyncio.sleep(1)
        print(".")
try :
    asyncio.run(main())
except Exception as e:
    print(e)
    sys.exit()
finally:
    asyncio.new_event_loop()  # Clear retained state
the result when I push the button : fn_1 is cancelled, not fn_2
what's wrong ?
thanks !
JP
kevinkk525
Re: asyncio : cancelling gathered tasks
Post by kevinkk525 » Sat Oct 24, 2020 5:55 pm
That's a bug that hasn't been fixed yet: https://github.com/micropython/micropython/issues/5798
I'm hoping that Damien will revisit uasyncio soon..
Kevin Köck
jpbihin
Post by jpbihin » Sat Oct 24, 2020 6:32 pm
Thanks Kevin !
in the meantime this is working fine...
pb = Pushbutton(p)
async def fn_1() :
    print(time.time())
async def fn_2() :
    print(time.time())
async def foo_1():
        await fn_1()
        print("in foo_1")
async def foo_2():
        await fn_2()
        print("in foo_2")
    foo_task_1.cancel()
    foo_task_2.cancel()
    print ("game over")
async def main() :
    global foo_task_1, foo_task_2
    foo_task_1 = asyncio.create_task(foo_1())
    foo_task_2 = asyncio.create_task(foo_2())
    while True :
        print(".")
try :
    asyncio.run(main())
    print(e)
    sys.exit()
finally:
