I2C LCD Display Driver Suggestion
atmuc
Post by atmuc » Fri Nov 13, 2020 2:43 pm
I use hd44780 display. I found some drivers in that page; https://awesome-micropython.com/
All of them use the old version of microPython. I tried to convert some of them, I still get some errors. Do you suggest a driver lib that works fine with the latest version of microPython?
Re: I2C LCD Display Driver Suggestion
Post by jimmo » Sat Nov 14, 2020 4:34 am
Nothing really major has changed, so it might be quite easy to update them. What errors do you see?
atmuc
Post by atmuc » Sat Nov 14, 2020 7:54 am
I solved the problem. I connected VCC to 3.3 V. When I connected it to 5V it worked.
