esp8266 UART error
Posted: Thu Nov 26, 2020 3:14 pm
by rave
I'm trying to test
https://github.com/chrisb2/micropython-fingerprint on my esp8266 and following the instructions, I fail to init the software UART:
from pyfingerprint import PyFingerprint
sensorSerial = UART(1)
sensorSerial.init(57600, bits=8, parity=None, stop=1, rx=13, tx=12)
The result of the last line:
ValueError: expecting a pin
I tried Pin(14) and '14' and can't seem to get the init to work. Any clue?
Re: esp8266 UART error
Posted: Fri Nov 27, 2020 1:19 am
by jimmo
rave wrote: ↑Thu Nov 26, 2020 3:14 pm
FWIW, this is not a "software" UART (there's no soft UARTs in MicroPython), and there's only one full hardware UART on the ESP8266 (which is also used for the REPL).
The tx and rx kwargs need to be machine.Pin instances, not integers. But you said you tried that -- did you get a different error?
Posted: Fri Nov 27, 2020 7:16 am
by Roberthh
@rave The lib you are trying to use is made for ESP32. Lacking a second UART, it will not work this way on a ESP8266. Using webrepl for the micropython prompt, you couls use UART0 for that purpose.
Posted: Fri Nov 27, 2020 8:13 am
by rave
That's disappointing
If this is the case, why do I need to declare the pins? Isn't it board depandant?
This is the error I get:
>>> sensorSerial.init(57600, bits=8, parity=None, stop=1, rx=machine.Pin(15))
ValueError: invalid tx/rx
Posted: Fri Nov 27, 2020 8:14 am
by rave
Roberthh wrote: ↑Fri Nov 27, 2020 7:16 am
And how do I do use UART0? Just emit the pins?
Posted: Fri Nov 27, 2020 8:59 am
by Roberthh
UART0 is fix assigned to the pins denoted as TX and RX. So do not have and cannot assign pins to it.
Posted: Fri Nov 27, 2020 9:31 am
by rave
Roberthh wrote: ↑Fri Nov 27, 2020 8:59 am
It’s seems to mess up with webrepl and hangs after the call to the sensor.
Sadly, reverting back to non-python, with software serial
I really wish a serial port emulation is implemented soon. I see a lot of people asking for that
Posted: Fri Nov 27, 2020 10:10 am
by Roberthh
You have to detach REPL on UARFT first, with
import uos
uos.dupterm(None, 1)
See:
http://docs.micropython.org/en/latest/e ... ckref.html
Posted: Sun Nov 29, 2020 7:14 am
by rave
Thanks. Tried that as well.
Still seem to hang on the sensor handshake. Moved back to my C code
WebREPL connected
>>> from machine import UART
>>> import uos
UART(0, baudrate=115200, bits=8, parity=None, stop=1, rxbuf=15, timeout=0, timeout_char=1)
>>> sensorSerial = UART(0)
>>> sensorSerial.init(57600, bits=8, parity=None, stop=1)
>>> f = PyFingerprint(sensorSerial)
>>> f.verifyPassword()
Disconnected
Posted: Sun Nov 29, 2020 7:42 am
by Roberthh
You can compine the set-up of the serial port to:
sensorSerial = UART(0, 57600)
All init parameters can be added to the object instantiation. It is ususally hard to tell what happens on a serial link without any kind of monitoring. Simple logic analyzers for about 10 USD do a perfect job there.
