If one were so inclined to take a stab at writing the code for a library to work with a particular sensor, where would you start? I'd like to especially learn how to port a library that is available for Arduino but not yet for Micropython.
Where would one start on this journed? What information would I need to be looking for?
Writing A Sensor Library/Driver
Re: Writing A Sensor Library/Driver
There is a nice talk about that: An Introduction to Hardware Drivers in Micro Python
To sum up:
To sum up:
- Understand the datasheet
- Know how to write/read to/from the sensor registers (it varies a bit depending on the protocol used I2C/SPI/UART)
- Also understanding bitwise operations, binary/hexadecimal numbering system and how this representations works in python will help a lot
Ex:Code: Select all
>>> bin(42) '0b101010' >>> hex(42) '0x2a' >>> 0b101010 42 >>> 0x2a 42 >>>
Outstanding! Thank you cqqlzpy.
cgglzpy wrote: ↑Tue Dec 15, 2020 6:37 pmThere is a nice talk about that: An Introduction to Hardware Drivers in Micro Python
To sum up:
Ex:Code: Select all
Since making this post I have been trying to find some simple device that uses I2C that I could attempt to write a library for, for the experience and the experience of it. However, I am coming up short. Does anyone have some ideas? I need to start with something relatively simple, not something like the BME680 or something insane like that. Something I can buy the sensor for and get the datasheet for and start working through the process of how to actually write the library and test it out.
You're my hero. How/Where did you learn to do that?
shaoziyang wrote: ↑Tue Dec 22, 2020 1:26 pmYou can refer to my micropython library:
https://github.com/micropython-Chinese- ... ty/mpy-lib
It's not difficult, just try more, and more discussion.
This is rather long, and I have not read through the whole thing as of yet, but it appears to be a good document on porting/writing libraries for sensors.
https://www.digikey.fi/fi/maker/project ... 1725f28b1b
