Non-blocking WiFi connection
PLUB
Post by PLUB » Fri Jan 08, 2021 6:16 pm
I don't speak perfect English and I use the Google translator ;) , sorry if the syntax is not perfect.
I had fun with an Arduino with C ++ and now I want to use an ESP32 in Micropython, which allows Wifi connections.
Most tutorials use a blocking loop to connect like:
in C:
While (WIFI.Status ()! = WL_CONNECTED) {
delay (500);
Serial.print (".")}
or in Python:
if not wlan.isconnected ():
print ('connecting to network ...')
wlan.connect ('essid', 'password')
while not wlan.isconnected ():
pass
print ('network config:', wlan.ifconfig ())
If the connection cannot be established, the ESP loops indefinitely and is lost.
However, I saw other Arduino tutorials that used WifiEventHandler.
Example:
WiFiEventHandler gotIpEventHandler, disconnectedEventHandler;
void setup ()
Serial.begin (115200);
Serial.println ();
gotIpEventHandler = WiFi.onStationModeGotIP ([] (const WiFiEventStationModeGotIP & event)
Serial.print ("Station connected, IP:");
Serial.println (WiFi.localIP ());
disconnectedEventHandler = WiFi.onStationModeDisconnected ([] (const WiFiEventStationModeDisconnected & event)
Serial.println ("Station disconnected");
Serial.printf ("Connecting to% s ... \ n", ssid);
WiFi.begin (ssid, password);
I didn't find anything in Micropython. Is it possible to have an equivalent solution?
Thank you in advance
Re: Non-blocking WiFi connection
Post by pythoncoder » Fri Jan 08, 2021 6:22 pm
I'd implement a timeout. Replace
    pass
with something like
from time import ticks_ms, ticks_diff
start = ticks_ms()
    if ticks_diff(ticks_ms(), start) > 10_000:  # 10 second timeout
        # It hasn't connected, take some kind of action
PLUB
Post by PLUB » Sat Jan 09, 2021 10:09 am
Thank you for your reply. I have already seen this solution, but during these 10s the ESP is blocked, and that whatever the delay.
If I understand correctly, the WifiEventHandler works like interrupts, which means non-blocking.
Is it correct?
Post by pythoncoder » Sat Jan 09, 2021 6:17 pm
I'm not sure what you mean when you say the ESP is blocked. This loop
is running: the isconnected() call is nonblocking. If you want to run concurrent tasks while waiting for a connection you need to use uasyncio. See the docs and this tutorial.
It is entirely possible to write asynchronous WiFi code, the one exception being socket.getaddrinfo(): DNS lookup currently blocks for the duration. Fixing this is work in progress.
For an example of an asynchronous WiFi application see resilient asynchronous MQTT.
PLUB
Post by PLUB » Sat Jan 09, 2021 7:41 pm
Thank you for this information.
I will read them and try to assimilate them.
Plub
