I am rebasing my port on the newest version of the upstream project and I am getting this error for lib/oofatfs/ffunicode.c and ff.c (after adjusting to the unicode.c rename):
mkdir -p build/genhdr
Create build/genhdr/pins.h
GEN build/genhdr/mpversion.h
GEN build/genhdr/moduledefs.h
GEN build/genhdr/pybcdc.inf
GEN build/genhdr/pybcdc_inf.h
GEN build/genhdr/qstr.i.last
../../lib/oofatfs/ffunicode.c:262:28: error: pasting "uc" and "(" does not give a valid preprocessing token
const WCHAR *p = CVTBL(uc, FF_CODE_PAGE);
../../lib/oofatfs/ffunicode.c:34:22: note: in definition of macro 'MERGE2'
#define MERGE2(a, b) a ## b
../../lib/oofatfs/ffunicode.c:262:22: note: in expansion of macro 'CVTBL'
../../lib/oofatfs/ffunicode.c:284:28: error: pasting "uc" and "(" does not give a valid preprocessing token
../../lib/oofatfs/ffunicode.c:284:22: note: in expansion of macro 'CVTBL'
../../lib/oofatfs/ff.c:559:37: error: pasting "TBL_CT" and "(" does not give a valid preprocessing token
static const BYTE ExCvt[] = MKCVTBL(TBL_CT, FF_CODE_PAGE);
../../lib/oofatfs/ff.c:422:26: note: in definition of macro 'MERGE_2STR'
#define MERGE_2STR(a, b) a ## b
../../lib/oofatfs/ff.c:559:29: note: in expansion of macro 'MKCVTBL'
../../py/mkrules.mk:88: recipe for target 'build/genhdr/qstr.i.last' failed
make: *** [build/genhdr/qstr.i.last] Error 1
#define MKCVTBL(hd, cp) MERGE_2STR(hd, cp)
If I replace them like this it compiles:
MKCVTBL(TBL_CT, FF_CODE_PAGE) -> TBL_CT ## FF_CODE_PAGE
Do I need special compiler flags to make this work?
I am using these:
-Wall -Werror -Wpointer-arith
-I. -I./mods -I./misc -I./cmsis -I../.. -Ibuild -Ibuild/genhdr -I/mnt/c/ti/TivaWare -I/mnt/c/ti/TivaWare/driverlib -I../../py -I./board -I../../ -Iusbdev/core/inc -Iusbdev/class/inc
-std=gnu99 -nostdlib -mthumb -mtune=cortex-m4 -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mabi=aapcs-linux -Og -fshort-enums -fdata-sections -ffunction-sections
-DPART_TM4C123GH6PM -DTM4C123GH6PM -DARMCM4_FP -DCMSIS_HEADER="ARMCM4_FP.h" -DTARGET_IS_TM4C123_RB1 -DMICROPY_PIN_DEFS_PORT_H="mods/pin_defs_tm4c123.h" -DFFCONF_H="lib/oofatfs/ffconf.h" -DMICROPY_LONGINT_IMPL=MICROPY_LONGINT_IMPL_MPZ -DMICROPY_FLOAT_IMPL=MICROPY_FLOAT_IMPL_FLOAT
-fsingle-precision-constant -Wdouble-promotion -ggdb
-DDEBUG -DPENDSV_DEBUG -DMICROPY_ROM_TEXT_COMPRESSION=1
Thanks in advance!
