Pure MicroPython Matrix (mathematics)
OlivierLenoir
Post by OlivierLenoir » Thu Jan 21, 2021 8:32 pm
https://gitlab.com/olivier.len02/MicroPython-Matrix
I wrote the following code to do basic matrix operations. It works for me, but I'm not sure it's the best way to do it.
Do you have recommendation?
Is it the right way when I use return Matrix(...)?
def add(a, b):
    return a + b
def sub(a, b):
    return a - b
def mul(a, b):
    return a * b
class Matrix(object):
    def __init__(self, mat):
        self.mat = mat
    def __repr__(self):
        return self.mat
    def __add__(self, b):
        return Matrix([list(map(add, *ab)) for ab in zip(self.mat, b.mat)])
    def __sub__(self, b):
        return Matrix([list(map(sub, *ab)) for ab in zip(self.mat, b.mat)])
    def __matmul__(self, b):
        return Matrix([[sum(map(mul, _a, _b)) for _b in zip(*b.mat)] for _a in self.mat])
>>> a = Matrix([[1, 2, 3], [4, 5, 6]])
>>> b = Matrix([[10, 11], [20, 21], [30, 31]])
>>> c = Matrix([[-23, 3, 8], [-13, 17, -21]])
>>> d = Matrix([[32, 17], [-3, 11]])
>>> a @ b
[[140, 146], [320, 335]]
>>> a + c
[[-22, 5, 11], [-9, 22, -15]]
>>> a - c
[[24, -1, -5], [17, -12, 27]]
>>> a @ b + d
[[172, 163], [317, 346]]
rcolistete
Re: Pure MicroPython Matrix (mathematics)
Post by rcolistete » Thu Jan 21, 2021 10:19 pm
I suggest to use some MicroPython modules with matrix operations :
https://github.com/mcauser/awesome-micr ... #analytics
Post by pythoncoder » Fri Jan 22, 2021 9:29 am
There is also ulab but that requires compiling the firmware.
OlivierLenoir
Post by OlivierLenoir » Fri Jan 22, 2021 5:11 pm
Thanks for your links.
Here is my on-going Matrix project.
OlivierLenoir
Post by OlivierLenoir » Wed Feb 03, 2021 8:00 pm
I'm getting this error TypeError: unsupported types for __add__: 'int', 'Matrix'. It seem to be link to def __radd__(self, other): but I need help. In fact my class Matrix works well with python 3.7.3 but not with micropython v1.13 or v1.14.
def add(a, b):
    return a + b
def sub(a, b):
    return a - b
def mul(a, b):
    return a * b
def square(a):
    return a * a
def eq(a, b):
    return a == b
        """Matrix A, list of list"""
        self.mat = mat
    def dim(self):
        """Matrix dimension m rows by n cols"""
        return len(self.mat), len(self.mat[0])
    def map(self, func):
        """Map function to all elements of the matrix"""
        return Matrix([list(map(func, m)) for m in self.mat])
    def sumsquare(self):
        """Sum square of elements"""
        return sum(sum(m) for m in self.actfunc(square).mat)
    def meansquare(self):
        """Mean square of elements"""
        return self.sumsquare() / mul(*self.dim())
    def t(self):
        """Matrix transpose"""
        return Matrix(list(zip(*self.mat)))
    def __str__(self):
        return '{}'.format(self.mat)
    def __repr__(self):
    def __neg__(self):
        """- A"""
        return self.map(lambda e: -e)
    def __pos__(self):
        """+ A"""
        return self.map(lambda e: e)
    def __add__(self, other):
        """A + B"""
        if not isinstance(other, Matrix):
            return Matrix([[_n + other for _n in _m] for _m in self.mat])
        return Matrix([list(map(add, *ab)) for ab in zip(self.mat, other.mat)])
        """B + A"""
        return self.__add__(other)
    def __iadd__(self, other):
        """A += B"""
        self.mat = self + other
        return self.mat
from matrix import Matrix
e = Matrix([[9, 8, 7], [6, 5, 4]])
print('a + c =', a + c)
print('a - c =', a - c)
print('a + 2 =', a + 2)
print('2 + a =', 2 + a)  # TypeError: unsupported types for __add__: 'int', 'Matrix'
Do you have an explanation?
Full project is available https://gitlab.com/olivier.len02/MicroPython-Matrix
Post by jimmo » Thu Feb 04, 2021 5:46 am
Which board are you using?
For __radd__ etc, you need MICROPY_PY_REVERSE_SPECIAL_METHODS to be enabled (which I think is only STM32/pyboard, Unix, and Windows)
If you're on ESP32 then you'll need to do a custom build. Or perhaps raise an issue on github to suggest getting them enabled by default for ESP32?
OlivierLenoir
Post by OlivierLenoir » Thu Feb 04, 2021 6:44 am
I'm using ESP32 board without SPIRAM and I plan to use the recent RPi PICO.
At that stage I don't feel confident to custom build my own version.
It would be a good idea to enable, __radd__(), __rsub__(), __rmul__()...
Can you help to raise an issue?
Post by jimmo » Fri Feb 05, 2021 12:16 am
I found https://github.com/micropython/micropyt ... -614417107
Maybe could you reply to that and suggest pico also?
OlivierLenoir
Post by OlivierLenoir » Fri Feb 05, 2021 3:55 pm
Thanks Jimmo,
I've added a comment link to issue #5897. Lets wait and see.
