Pure MicroPython Matrix (mathematics)
Posted: Thu Jan 21, 2021 8:32 pm
by OlivierLenoir
https://gitlab.com/olivierlenoir/MicroPython-Matrix
I wrote the following code to do basic matrix operations. It works for me, but I'm not sure it's the best way to do it.
Do you have recommendation?
Is it the right way when I use
return Matrix(...)?
def add(a, b):
return a + b
def sub(a, b):
return a - b
def mul(a, b):
return a * b
class Matrix(object):
def __init__(self, mat):
self.mat = mat
def __repr__(self):
return self.mat
def __add__(self, b):
return Matrix([list(map(add, *ab)) for ab in zip(self.mat, b.mat)])
def __sub__(self, b):
return Matrix([list(map(sub, *ab)) for ab in zip(self.mat, b.mat)])
def __matmul__(self, b):
return Matrix([[sum(map(mul, _a, _b)) for _b in zip(*b.mat)] for _a in self.mat])
>>> a = Matrix([[1, 2, 3], [4, 5, 6]])
>>> b = Matrix([[10, 11], [20, 21], [30, 31]])
>>> c = Matrix([[-23, 3, 8], [-13, 17, -21]])
>>> d = Matrix([[32, 17], [-3, 11]])
>>> a @ b
[[140, 146], [320, 335]]
>>> a + c
[[-22, 5, 11], [-9, 22, -15]]
>>> a - c
[[24, -1, -5], [17, -12, 27]]
>>> a @ b + d
[[172, 163], [317, 346]]
Re: Pure MicroPython Matrix (mathematics)
Posted: Thu Jan 21, 2021 10:19 pm
by rcolistete
I suggest to use some MicroPython modules with matrix operations :
https://github.com/mcauser/awesome-micr ... #analytics
Posted: Fri Jan 22, 2021 9:29 am
There is also
ulab but that requires compiling the firmware.
Posted: Fri Jan 22, 2021 5:11 pm
by OlivierLenoir
Thanks for your links.
Here is my on-going
Matrix project.
Posted: Wed Feb 03, 2021 8:00 pm
by OlivierLenoir
I'm getting this error
TypeError: unsupported types for __add__: 'int', 'Matrix'. It seem to be link to
def __radd__(self, other): but I need help. In fact my class
Matrix works well with
python 3.7.3 but not with
micropython v1.13 or v1.14.
def add(a, b):
return a + b
def sub(a, b):
return a - b
def mul(a, b):
return a * b
def square(a):
return a * a
def eq(a, b):
return a == b
"""Matrix A, list of list"""
self.mat = mat
def dim(self):
"""Matrix dimension m rows by n cols"""
return len(self.mat), len(self.mat[0])
def map(self, func):
"""Map function to all elements of the matrix"""
return Matrix([list(map(func, m)) for m in self.mat])
def sumsquare(self):
"""Sum square of elements"""
return sum(sum(m) for m in self.actfunc(square).mat)
def meansquare(self):
"""Mean square of elements"""
return self.sumsquare() / mul(*self.dim())
def t(self):
"""Matrix transpose"""
return Matrix(list(zip(*self.mat)))
def __str__(self):
return '{}'.format(self.mat)
def __repr__(self):
def __neg__(self):
"""- A"""
return self.map(lambda e: -e)
def __pos__(self):
"""+ A"""
return self.map(lambda e: e)
def __add__(self, other):
"""A + B"""
if not isinstance(other, Matrix):
return Matrix([[_n + other for _n in _m] for _m in self.mat])
return Matrix([list(map(add, *ab)) for ab in zip(self.mat, other.mat)])
"""B + A"""
return self.__add__(other)
def __iadd__(self, other):
"""A += B"""
self.mat = self + other
return self.mat
from matrix import Matrix
e = Matrix([[9, 8, 7], [6, 5, 4]])
print('a + c =', a + c)
print('a - c =', a - c)
print('a + 2 =', a + 2)
print('2 + a =', 2 + a) # TypeError: unsupported types for __add__: 'int', 'Matrix'
Do you have an explanation?
Full project is available
Posted: Thu Feb 04, 2021 5:46 am
by jimmo
OlivierLenoir wrote: ↑Wed Feb 03, 2021 8:00 pm
It seem to be link to def __radd__(self, other):
Which board are you using?
For __radd__ etc, you need MICROPY_PY_REVERSE_SPECIAL_METHODS to be enabled (which I think is only STM32/pyboard, Unix, and Windows)
If you're on ESP32 then you'll need to do a custom build. Or perhaps raise an issue on github to suggest getting them enabled by default for ESP32?
Posted: Thu Feb 04, 2021 6:44 am
by OlivierLenoir
I'm using ESP32 board without SPIRAM and I plan to use the recent RPi PICO.
At that stage I don't feel confident to custom build my own version.
It would be a good idea to enable, __radd__(), __rsub__(), __rmul__()...
Can you help to raise an issue?
Posted: Fri Feb 05, 2021 12:16 am
by jimmo
OlivierLenoir wrote: ↑Thu Feb 04, 2021 6:44 am
I found
https://github.com/micropython/micropyt ... -614417107
Maybe could you reply to that and suggest pico also?
Posted: Fri Feb 05, 2021 3:55 pm
by OlivierLenoir
Thanks Jimmo,
I've added a comment link to issue #5897. Lets wait and see.
