TrickLED - NeoPixel WS2812B Animation Library
artacus
Post by artacus » Thu Jan 28, 2021 8:57 pm
Hey folks. I've been lurking here for a while and wanted to make my introduction with a small gift for you fine people.
I've been working on an animation library for MicroPython. There's no reason the Arduino folks should have all of the fun!
I wrote if for the ESP32 but it runs fine on an ESP8266 if you use the *.mpy files instead. I put a demo video up on Youtube here https://www.youtube.com/watch?v=vLvrJPNvkvU
But the colors didn't come across at all on the video, so load up a copy onto your board and see it live.
https://gitlab.com/scottrbailey/trickLED
Shout out to Peter Hinch. Even though you didn't know it, you were immensely helpful. Thanks for your contributions to the community.
Artacus
Primesty
Re: TrickLED - NeoPixel WS2812B Animation Library
Post by Primesty » Sat May 01, 2021 3:19 pm
Hi Artacus!
This library is fantastic! Thanks a lot for this!
I have one question though. I'm trying to run your example on an ESP32 with MicroPython 1.15 and am getting import errors.
I have
trickLED.py
, as well as
animations.py
and
generators.py
installed and this is your example code I'm trying to run to get started:
import uasyncio as asyncio
import trickLED
from trickLED import animations
from trickLED import generators
# use TrickLED class instead of NeoPixel
tl = trickLED.TrickLED(machine.Pin(19), 4)
tl.fill((50, 50, 50), start_pos=0, end_pos=2) # fill first 25 pixels with white
tl.fill_gradient(0xDC143C, 0xF08080, 3) # fill remaining with red gradient
tl.write()
Two things are basically happening: 1) When I run the code without the animations/generators import, I get an error about function arguments:
  File "main.py", line 11, in <module>
TypeError: unexpected keyword argument 'start_pos'
MicroPython v1.15 on 2021-04-18; ESP32 module with ESP32
And 2) when I'm trying to import generators/animations, I get this error (for both and also individually):
  File "main.py", line 5, in <module>
ImportError: can't import name animations
What am I doing wrong here? I assume there might be some circular dependency issue? Also, would you be willing to share the code for the animations/examples in your Youtube video?
SpotlightKid
Post by SpotlightKid » Thu May 06, 2021 2:55 pm
You probably need to copy the whole trickLED directory with its content to your ESP32 board's flash. Not just the *.py files in it.
sgar
Post by sgar » Fri May 07, 2021 9:16 am
Awesome library! Congratulations!
I will try to use it in my project :D Thanks!!
Primesty
Post by Primesty » Fri May 07, 2021 6:15 pm
@Spotlightkid, good thought! I tried that but it threw the same error.
Does anyone have any setup instructions and examples that run reliably on MicroPython 1.15 and an ESP32??
SpotlightKid
Post by SpotlightKid » Fri May 07, 2021 7:05 pm
I had a look at the trickLED code and I can't see how you would get the errors you get if you have the package installed correctly on your board.
I would take these steps to install the library:
rshell rm -r /pyboard/trickLED
rshell mkdir /pyboard/trickLED
for py in trickLED/*.py; do
    mpy-cross "$py"
done
rshell cp trickLED/*.mpy /pyboard/trickLED
Add options for the serial device and baudrate to the rshell commands as necessary.
sgar
Post by sgar » Tue May 11, 2021 10:06 am
@artacus any chance to configure brightness in Fire animation and/or flip the direction of the animations? (Fire start from last led)
Thanks!
Primesty
Post by Primesty » Wed May 12, 2021 3:16 pm
@sgar
Do you mind posting your sample code or a link to a repo with the code you’re running? Are you using an ESP32? How did you install the trickLED lib?
I tried installing the entire folder, but am still getting an error.
sgar
Post by sgar » Fri May 14, 2021 9:08 am
@sgar
No worries :) :
I'm running the main.py demo from the library with the folow lines modified:
Line 170: Changed the pin where I have connected the leds.
Line 176: Commented, to avoid any wifi connection
Running with Thonny, ESP32, only copied the .py files and it works well, here you can see the setup.
https://i.ibb.co/yNvZGzS/14-05-2021-10-54-53-REC.png
Primesty
Post by Primesty » Sun May 16, 2021 9:40 pm
Hi Sgar,
Thanks, I’ll give that a shot.
