UART and end of line
161616harvard
Post by 161616harvard » Fri Feb 12, 2021 7:50 pm
I'm trying to read 40 bytes from uart.readline() in micropython. However the reading stops when it encounters \x00.
Example.
"\xff\xff\xff\xff\x01\x00\x05\x07\x02\x44\x45\x41\"
uart.readline() returns b'\xff\xff\xff\xff\x01'
Can someone shed a light into this? Why does it convert to ascii and How can I read the 0 byte and the rest?
kevinkk525
Re: UART and end of line
Post by kevinkk525 » Fri Feb 12, 2021 7:59 pm
If you are trying to read exactly 40 bytes, why are you using uart.readline()? You should be using uart.read(40)
But even then it might return less bytes if it reads faster than the other end sends bytes.
Kevin Köck
161616harvard
Post by 161616harvard » Fri Feb 12, 2021 8:12 pm
I added at the end he byte 0x0A for end of line, but I could use the uart.read(40)
I still have the same problem with \x00 byte since the reading stops there. Is there a solution to that?
kevinkk525
Post by kevinkk525 » Fri Feb 12, 2021 8:34 pm
What hardware are you using?
if you use uart.readline() maybe it stops because it considers \x00 the end of a line? i don't know. I only use read()
Kevin Köck
161616harvard
Post by 161616harvard » Fri Feb 12, 2021 9:44 pm
I switched to the function readinto and I get better results. Thank you friend for your answer though!
