Looking at the urllib.urequest code, it seems there is no header support at all. That's the reason why my current request is failing. Is there a chance to get header support implemented soon?
import urllib.urequest
endpoint = 'https://api.yaas.io/hybris/oauth2/b1/token'
urlencoded = 'grant_type=client_credentials&scope=&client_id=xxx&client_secret=xxx'
headers = {'Content-Type': 'application/x-www-form-urlencoded'}
response = urllib.urequest.urlopen(endpoint, data=urlencoded, method="POST")
json = response.read()
//FAILS - no Content-Type specified and the API does not seem to support it right now.
Header support in urllib or requests
Re: Header support in urllib or requests
You can use urequests instead, which has support for headers.
Unfortunately, it doesn't. Let's see if this gets reported on github, so maintainers didn't forget to fix it
Awesome MicroPython list
Also, it seems that urllib.urequest does support headers:
response = urllib.urequest.urlopen(endpoint, data=urlencoded, headers=headers, method="POST")
Arbitrary headers support has been added to urequests. Please test it and report results.
