How do I install esptool on Windows
Pithon
Post by Pithon » Sat Nov 11, 2017 9:50 pm
I've just downloaded Python 3.6.3 64-bit and am trying to follow these instructions:
https://docs.micropython.org/en/latest/ ... intro.html
pip install esptool
does not work when I type it into Python. It returns a syntax error?
chrisb2
Re: How do I install esptool on Windows
Post by chrisb2 » Mon Nov 13, 2017 6:23 am
That version of Python should come with pip already install. What error do you get?
What is the result of running the following at the DOS prompt:
python -V
pip -V
ccooper21
Post by ccooper21 » Mon Nov 13, 2017 8:15 pm
"pip" is a command line tool that you run from the Windows command prompt as opposed to via the Python text interface (i.e. the REPL). In other words, you'll need to run the "pip install esptool" command before starting "python". In fact, when using "pip" to install "esptool", it will create an "esptool.exe" file in the "Scripts" directory of your Python installation. You can hence run "esptool" from the Windows command prompt and it will take care of invoking Python for you in order to run.
-- Chris
