Hi,chrisgp wrote: ↑Wed Oct 05, 2016 5:00 amI implemented a trivial telnet server for MicroPython/ESP8266 that will run in the background and give telnet clients access to the REPL. The code is here: https://github.com/cpopp/MicroTelnetServer
I've only tested with the mac telnet client, but to use it you just throw utelnetserver.py on your ESP8266 and add the following lines to boot.py
and from there you should be able to telnet to your ESP8266.Code: Select all
import utelnetserver utelnetserver.start()
I tried implementing it any never succeed. I have stored the file into my /lib/utelnet/utelnetserver.py and tried to import it using these on boot.py
import /lib/utelnet/utelnetserver
Please guide me
