ssd1306 not working??
I tried to use a ssd1306 OLED on an ESP8266 board.
Program is exactly as in the µPy reference, and I got an error.
i2c is previously defined as : i2c = I2C(scl=Pin(5), sda=Pin(4))
And in the following line there is an error...
display = ssd1306.SSD1306_I2C(128, 64, i2c)
Interpreter says there is an argument missing, but neither in the original ssd1306 library nor in the Quick reference I've seen more than these 3 arguments...
I'm relatively new to µPy, so I may have missed something!
Thanks for help
Thanks for help
Re: ssd1306 not working??
So you also used the ssd1306.py file from the MicroPython repository at https://github.com/micropython/micropyt ... ssd1306.py ?
What exactly is the error message?
Hi Robert, and thanks for answer.
As far as I could cross check, yes, the library is the correct one.
I downloaded it directly from Thonny menu.
Here is the error I got:
>>> %Run -c $EDITOR_CONTENT
File "<stdin>", line 5, in <module>
TypeError: function missing 1 required positional arguments
Line 5 is the bold one in my previous post.
Just to be complete, the whole module, exactly as in the Quick reference...:
import ssd1306
display.text('Hello World', 0, 0, 1)
display.show()
Gerard.
import ssd1306
display.show()
Gerard.
I do not trust Thonny on that respect. Try to load the code to the device und run it from to he REPL prompt.
I got exactly the same error with µPycraft...
I did copy, one line after the other in the REPL, and when it comes to the "display =..." I still get the same error message.
I tried the same on my ESP8266 here. I do not own a SSD1306, so I just ran it without a display.
I get as expected a ETIMEDOUT error on the attempt so send commands to the display. But the display is instantiated fine.
Which firmware version do you use?
You're missing the first parameter, which tells the class what type of board. Try the following:
i2c = I2C(0, scl=Pin(5), sda=Pin(4), freq=400000)
@femtopy: The statement instantiation the I2C object is correct. The initial poster uses an ESP8266 board, which implements SoftI2C only. SoftI2C does not require an I2C id.
I just tried his code on my Pico with SSD1306 using Thonny and the error is due to the missing id.
