DS18B20 error
Re: DS18B20 error
Post by Roberthh » Fri Jan 15, 2021 9:18 pm
What I understand: While the above script is running, you disconnect the sensor.
In that case, the read function will read invalid data, obviously with a wrong CRC, and raises a CRC error. That is the expected behavior.
In your script you can catch the CRC error with try/except clause around read.temp(), e.g. as:
            print (ds.read_temp (rom), end = '|')
       except CRCError:
           print("CRC error reading the termperature, unit", rom)
In that case, the script will continue and print error message until you reconnect the sensor.
Obviously, you may implement any reasonable error handling instead.
SirN Check
Re: DS18B20 error
Post by SirN Check » Tue Feb 02, 2021 1:24 am
Additional response to bayardi
You need the 750ms delay placed directly after the ds.convert_temp().
Best regards
