Having issues with trying to catch "OneWireError" exception
davef
Re: Having issues with trying to catch "OneWireError" exception
Post by davef » Mon Mar 29, 2021 10:50 pm
def reset(self, required=False):
(line 22)        reset = _ow.reset(self.pin)
        if required and not reset:
            raise OneWireError
return reset
at https://github.com/micropython/micropyt ... onewire.py
Hmmm. I had issues with external electrical disturbance messing with my 1-wire on the RaspberryPi.
Swap sensors and see if the problem follows?
rpi_nerd
Post by rpi_nerd » Tue Mar 30, 2021 1:43 am
IIRC I had the same issue when using another sensor some time ago before I swapped it out for the current one (think the reason for swapping was that I wanted a longer cable.)
davef
Post by davef » Tue Mar 30, 2021 3:18 am
Just to clarify ... swap sensors and see if the problem moves to the other pin. Have you also tried setting up just one 1-wire pin and seeing if that specific sensor still faults?
4K7 pull-up and normal mode?
Good luck!
kevinkk525
Post by kevinkk525 » Tue Mar 30, 2021 5:21 am
You might need to catch "onewire.OneWireError"
Kevin Köck
rpi_nerd
Post by rpi_nerd » Tue Mar 30, 2021 11:32 am
That works! Thanks!
rpi_nerd
Post by rpi_nerd » Tue Mar 30, 2021 11:37 am
Good luck!
Yes to both 4K7 pull-up and normal mode.
Up until recently I was just using one sensor. Now come to think about it, I've had similar issues with non 1-wire sensors such as the DHT22(on a different pin.)
davef
Post by davef » Tue Mar 30, 2021 6:50 pm
What specific ESP8266 board and how are you powering it? I would comment out send_data() and print-out or log any failures you get. Maybe it is a powering issue.
rpi_nerd
Post by rpi_nerd » Thu Apr 01, 2021 2:53 am
I'm using a D1 board with the Arduino Uno form-factor and powering it with a 12V wall wart thru the barrel jack. I've also taken to opportunity to update the firmware to the latest version.
davef
Post by davef » Thu Apr 01, 2021 3:46 am
Current rating of the 12V Wall-mart and what 12V to 3V3 regulator chip on D1? Commenting-out the send_data() should remove any high peak current issues with the supply system.
davef
Post by davef » Fri Apr 02, 2021 6:07 am
Hi Kevin,
import ds18x20
except OneWireError as error:
        with open('errors.txt', 'a') as outfile:
            outfile.write(str(error) + '\n')
    except OSError:
        pass
and
except onewire.OneWireError as error:
    except OSError:
        pass
Both seems to work in the sense that I don't get any
errors, but are they both gathering the same information?
Also, I have seen this example:
        print (ds.read_temp (rom), end = '|')
    except CRCError:
        print("CRC error reading the temperature, unit", rom)
I don't see CRCError in onewire.py so I guess CRCError is defined
somewhere else, but where?
In ds18x20.py I see:
 raise Exception("CRC error")
but still no CRCError
Thanks,
Dave
