Get current UART settings
microBoa
Post by microBoa » Thu Apr 08, 2021 1:26 am
I'm trying to create a configuration function that reads the current settings and prompts the user if they want to change it.
Is there a way for example to get only the current baudrate and not a tuple? of all the settings?
>>> uart = UART(0, 115200)
Now at the REPL I type 'uart' and I get something like:
UART(0, baudrate=115200, bits=8, parity=None, stop=1, rxbuf=15, timeout=10, timeout_char=10)
How do I get just the baudrate, or just the parity without having to parse the line?
EDIT: For example, in Lua I would do this:
baud, databits, parity, stopbits = uart.getconfig(0)
microBoa
Re: Get current UART settings
Post by microBoa » Thu Apr 08, 2021 7:39 am
I still don't know if there's a more 'pythonic' way to do this, but in case anyone else wants to do it, this is what I whipped up for now.
import ure
def uart_cfg(device):
  cfg = ure.search('.*\((.*)\)', str(UART(device))).group(1).split(',')
  return cfg[1].split('=')[1], cfg[2].split('=')[1], cfg[3].split('=')[1], cfg[4].split('=')[1]
call it with the UART number like so:
uart_cfg(0)
Collect the output like this:
baud, databits, parity, stopbits = uart_cfg(0)
microBoa
Post by microBoa » Thu Apr 29, 2021 2:54 am
Here's a one liner for my previous post in case anyone wants to retrieve UART settings in the future:
_baud, _databits, _parity, _stopbits = tuple([x.split('=')[1] for x in str(UART(0))[8:-1].split(",")[:4]])
You can change the ':4' to ':7' if you want to also get the buffer/timeout settings.
JennaSys
Post by JennaSys » Tue Jul 27, 2021 1:06 am
Playing with Python, this turns the UART object into a subscriptable dictionary (works with uPy 1.16 but is subject to breaking with any update to the UART repr):
dict([val.strip().split('=') for val in ('channel=' + str(uart).strip(')').split('(')[1:][0]).split(',')])
Which turns this repr:
UART(0, baudrate=115200, bits=8, parity=None, stop=1, rxbuf=15, timeout=0, timeout_char=1)
into this dict:
{'baudrate': '115200', 'bits': '8', 'parity': 'None', 'timeout': '0', 'timeout_char': '1', 'stop': '1', 'channel': '0', 'rxbuf': '15'}
John Sheehan
