ESP8266 Bootloop after some seconds
Hello All,
After several tryials with a couple of ESP8266 model with the NodeMCU dev board I am not able to work with the micropython "script".
I tried to load the FW into the board with the esptool.py (also with espsetup-master) with all the combinations possibles read in the forums and videos but with no success. After some seconds with the putty opened I can see how it reboots with no chance to run more than a couple of lines.
I also put an external power supply because I have readed many times about with no success.
Yesterday, looking to another sollutions in youtube, I tried to erase the flash with the arduino IDE and running the "blink" example with in C++ and it worked. I am now trying to develop the Code for this application in C++ but it´s slower for me, I programmed a long time ago in C++ and I am used to do it in python so micropython is much better for me.
Any ideas about how could I solve this issue?
Many thanks. Regards,
Re: ESP8266 Bootloop after some seconds
can you tell us, please:
- what board you have: there are lots of NodeMCU variants, all slightly different.
- how much flash is on board. There's a script in the Arduino ESP8266 package which will work that out for you and display it in the terminal.
- what esptool.py command line you used, exactly: please copy and paste as text from your terminal
- what error messages/output you got
- how you are trying to connect to the REPL afterwards: application, port, speed, …
Many thanks for your quick answer.
I hope the following info is the one you are requiring me:
import esp
esp.check_fw()
md5; fccbe03ec7fd06fcfa29ccb626bb3db1
True
FlashROM:
Flash ID: 1640ef (Vendor: ef Device: 4016)
Flash bootloader data:
Byte @2: 02
Byte @3: 40 (Flash size: 4MB Flash freq: 40MHZ)
Firmware checksum:
md5: b2830d305b46654ba5a43108f3750c52
True
import port_diag
Networking:
STA ifconfig: ('0.0.0.0', '0.0.0.0', '0.0.0.0', '208.67.222.222')
AP ifconfig: ('192.168.4.1', '255.255.255.0', '192.168.4.1', '208.67.222.222')
Free WiFi driver buffers of type:
0: 8 (1,2 TX)
1: 0 (4 Mngmt TX(len: 0x41-0x100))
2: 8 (5 Mngmt TX (len: 0-0x40))
3: 4 (7)
4: 7 (8 RX)
lwIP PCBs:
Active PCB states:
Listen PCB states:
TIME-WAIT PCB states:
ANSWER FROM SERIAL COMM:
MicroPython v1.14 on 2021-02-02; ESP module (1M) with ESP8266
>>> import math
ets Jan 8 2013,rst cause:4, boot mode:(3,7)
wdt reset
load 0x40100000, len 30712, room 16
tail 8
chksum 0xd1
load 0x3ffe8000, len 996, room 0
tail 4
chksum 0x6b
load 0x3ffe83f0, len 1064, room 4
tail 4
chksum 0x4a
csum 0x4a
▒▒▒▒o▒r▒▒g|▒
dldl`▒▒s▒l▒l
l`▒▒{▒d▒d▒
$`▒▒s▒l▒▒▒
dl s$▒▒sl▒▒▒c▒▒c▒b
#{▒s▒n▒og▒
l▒▒l
d▒▒dl▒▒▒▒▒▒d▒g▒▒▒▒bl
$▒sp
▒▒▒▒c
l▒#{$sdr▒g▒▒▒▒▒oܟ▒c8
l▒▒l▒▒
The putty configuration is the following:
BaudRate: 115200
Data bits: 8
Stop bits: 1
Parity: None
FlowControl: None
import esp
esp.check_fw()
True
FlashROM:
Byte @2: 02
Firmware checksum:
True
import port_diag
Networking:
0: 8 (1,2 TX)
3: 4 (7)
4: 7 (8 RX)
lwIP PCBs:
Active PCB states:
Listen PCB states:
>>> import math
wdt reset
tail 8
chksum 0xd1
tail 4
chksum 0x6b
tail 4
chksum 0x4a
csum 0x4a
▒▒▒▒o▒r▒▒g|▒
dldl`▒▒s▒l▒l
l`▒▒{▒d▒d▒
$`▒▒s▒l▒▒▒
dl s$▒▒sl▒▒▒c▒▒c▒b
#{▒s▒n▒og▒
l▒▒l
$▒sp
▒▒▒▒c
l▒▒l▒▒
BaudRate: 115200
Data bits: 8
Stop bits: 1
Parity: None
FlowControl: None
You seem to use the 1MB firmware. Did you try the 2MB+ firmware too? https://micropython.org/resources/firmw ... -v1.14.bin, or the daily build https://micropython.org/resources/firmw ... ffda17.binMicroPython v1.14 on 2021-02-02; ESP module (1M) with ESP8266
The information with the version sent by you (I have tested with many versions in the repository):
MicroPython v1.14 on 2021-02-02; ESP module with ESP8266
>>> import math
>>> math
wdt reset
tail 8
chksum 0xd5
tail 4
chksum 0x2e
tail 4
chksum 0xfd
csum 0xfd
▒▒▒▒o▒;▒▒g|▒
lld$`▒▒s▒l▒l
l`▒▒{▒d▒l
d`▒▒r▒l
dl sd▒▒sl▒▒▒c▒▒c▒#
c{▒r
▒▒'▒ng▒
l▒▒l
dćdl▒▒▒▒▒▒d▒g▒▒▒▒b$
d▒sp
▒▒▒cl▒#s$sd;▒g▒▒▒▒▒o▒▒▒b8
$DŽl▒▒
Can you try other flash modes, like dout?
Also, can you try a different USB cable, in case that it is a power problem.
I have just tried with:
espsetup.py -port COM9 -fm dio 0
The situation with this is even wrost, the led is blinking so fast and I have no time to write anythin in the REPL mode.
I have also changed from usb port, usb cable and also from a PC to a raspberry pi.
Thanks for the help.
OK. so -fm=dout seems to work better. At least MP starts. If you do not touch REPL, does it reboot too?
Another measure some people took was adding a capacitor between the EN pin and GND, and ensuring that EN is properly pulled high by a resistor.
Someone had a similar problem here related to their WiFi environment – worth a try if the usual measures don’t help.
Many thanks! The issue is solved running as soon as REPL lets you paste some orders:Christian Walther wrote: ↑Tue Apr 13, 2021 6:28 pmSomeone had a similar problem here related to their WiFi environment – worth a try if the usual measures don’t help.
>>> import network
>>> network.WLAN(network.AP_IF).active(False)
As it is in that thread!
