file copy .py on board
dorad
Post by dorad » Fri May 14, 2021 2:30 pm
i seek a method to copy a file on the board
i find uos.rename() , etc ... but what comand use for copy a file .py ( for exemple blink.py to main.py)
thanks by advance
Roger
Re: file copy .py on board
Post by Roberthh » Fri May 14, 2021 7:19 pm
There is no built-in method for that. You have to use a little python script. e.g.
import os
def copy(s, t):
        if os.stat(t)[0] & 0x4000:  # is directory
            t = t.rstrip("/") + "/" + s
    except OSError:
        pass
    with open(s, "rb") as s:
        with open(t, "wb") as t:
                l = s.read(512)
                if not l: break
                t.write(l)
And the call:
from <script_name> import copy
copy(source, target)
If target is a directory, the source file will be copied into that directory.
