importing blynklib_mp.py issue
rambler_wf
Post by rambler_wf » Sat May 15, 2021 9:00 am
Hello Ladies/Gents, I tried importing blynklib_mp.py, and got error as follow:
             File "<stdin>", line 2, in <module>
             MemoryError: memory a
import machine,time,network
import blynklib_mp as blynklib
#blynk=blynklib.Blynk(Auth)
wf=network.WLAN(network.STA_IF)
wf.active(True)
wf.scan()
wf.connect("testwifi","testwifi123")
while(wf.isconnected==False):
    print('connecting...')
print(wf.ifconfig())
I've coped the blynklib_mp.py to ESP01(1M flash) board, is there anything wrong?
Thank you!
timmer
Re: importing blynklib_mp.py issue
Post by timmer » Wed Jun 09, 2021 11:13 am
I have a similar issue with the NodeMCU V3 (4MB). The system does not recognize the 'blynklib_mp' library, despite I placed it in a /lib folder on the NodeMCU.
I got earlier a the same memory error as you, but using and placing 'blynklib' in a /lib folder on the device solved that problem.
I use Thonny to interface.
Any idea why I get an unrecognized 'blynklib_mp' error ?
