TypeError: can't convert function to int
jayjoshi
Post by jayjoshi » Thu May 27, 2021 6:29 am
Hello there, I want to make a program in ESP8266 in which I will controll an ON BOARD LED with a webpage as well as My ESP8266 will send a Message to the WEBPAGE whenever I press button connected with GPIO 5 using Interrupt. But i am having Error.
The Error :
Connection successful
('192.168.43.150', '255.255.255.0', '192.168.43.72', '192.168.43.72')
  File "<stdin>", line 80, in <module>
The Code :
  import usocket as socket
except:
  import socket
from time import sleep
import urequests
from machine import Pin,Timer
import esp
esp.osdebug(None)
import gc
gc.collect()
ssid = 'Memesterr'
password = 'asdfghjkl'
station = network.WLAN(network.STA_IF)
station.active(True)
station.connect(ssid, password)
while station.isconnected() == False:
  pass
# Complete project details at https://RandomNerdTutorials.com
print('Connection successful')
print(station.ifconfig())
led = Pin(2, Pin.OUT)
button=Pin(5,Pin.IN)
def web_page():
  if led.value() == 1:
    state="ON"
  elif led.value()==0:
    state="OFF"
  html = """<html>
    <head>
    <title>ESP Web Server</title>
    <meta name="viewport" content="width=device-width, initial-scale=1">
    </head>
    <body> <h1>ESP Web Server</h1>
    <p>LED is <strong>""" + state + """</strong></p><p>
    <form>
        <br><button name="LED" value="0" type="submit">ON</button>
        <br><button name="LED" value="1" type="submit">OFF</button>
    </form>
    </body>
    </html>"""
  return html
def req_page():
  html="""<html>
  <head>
  </head>
  <body> <h1>REQUEST</h1>
  <p>Request From ESP8266</p>
  </body>
  </html>
  return html
def SendPage(self):
    SendState=True
SendState=False
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
s.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
s.bind(('', 80))
s.listen(5)
button.irq(machine.Pin.IRQ_FALLING,SendPage)
  conn, addr = s.accept()
  print('Got a connection from %s' % str(addr))
  request = conn.recv(1024)
  request = str(request)
  print('Content = %s' % request)
  led_on = request.find("/?LED=0")
  led_off = request.find("/?LED=1")
  #led_on.irq(request)
  if SendState==False:
    if led_on == 6:
      print('LED ON')
      led.value(1)
    elif led_off == 6:
      print('LED OFF')
      led.value(0)
    response = web_page()
    conn.send('HTTP/1.1 200 OK\n')
    conn.send('Content-Type: text/html\n')
    conn.send('Connection: close\n\n')
    conn.sendall(response)
    #print("response",response)
    conn.close()
  elif SendState==True:
    req=req_page()
    conn.sendall(req)
    conn.close()
Also pls tell me that wheater this Code is Correct or Not
rizarefaldi
Re: TypeError: can't convert function to int
Post by rizarefaldi » Wed Jun 02, 2021 6:32 pm
Hello there, I want to make a program in ESP8266 in which I will controll an ON BOARD LED with a webpage as well as My ESP8266 will send a Message to the WEBPAGE whenever I press button connected with GPIO 5 using Interrupt a4. But i am having Error.
The Error :
The Code :
except:
  import socket
import urequests
import esp
esp.osdebug(None)
import gc
gc.collect()
ssid = 'Memesterr'
  pass
def web_page():
    state="ON"
    state="OFF"
  html = """<html>
    <head>
    </head>
    <form>
    </form>
    </body>
    </html>"""
  return html
def req_page():
  html="""<html>
  <head>
  </head>
  </body>
  </html>
  return html
def SendPage(self):
    SendState=True
SendState=False
s.bind(('', 80))
s.listen(5)
    if led_on == 6:
      print('LED ON')
      led.value(1)
    elif led_off == 6:
      print('LED OFF')
      led.value(0)
    conn.close()
    req=req_page()
    conn.sendall(req)
    conn.close()
getting the same issue. Did you fix this problem? please update the thread if you have the solution.
Post by dhylands » Wed Jun 02, 2021 6:47 pm
If I'm reading this correctly, line 80 is this line:
This tells me that button.irq is expecting the second argument to be an int and you're passing in a function (SendPage).
Looking at the documentation: http://docs.micropython.org/en/latest/l ... ne.Pin.irq it shows that the handler should be the first argument and the trigger should the second, so you either need to name your arguments:
button.irq(trigger=machine.Pin.IRQ_FALLING, handler=SendPage)
or reorder them:
button.irq(SendPage, machine.Pin.IRQ_FALLING)
Disclaimer: I don't sue the esp8266 so I'm basing my answer purely off of the error and the docs.
lesmanaharmonic
Post by lesmanaharmonic » Mon Jul 05, 2021 10:14 am
Hi all,
i just wanna to ask what is the function of this number '6' of these script
if led_on == 6:
print('LED ON')
Thanx for answer
Post by Roberthh » Mon Jul 05, 2021 10:22 am
If you look into the script where the value of led_on is set, you'll find:
So led_on tells the position of the string "/?LED=0" in the string request. It is expected to be at the position 6, which is the 7th character of the string request.
lesmanaharmonic
Post by lesmanaharmonic » Wed Jul 07, 2021 8:41 am
Thanks Robert for explanations..
