My system is ubuntu 20.1
since I think esp-open-sdk is old, I've got the latest toolchain from here. https://github.com/espressif/ESP8266_RTOS_SDK. And I have done the path as well.
$ xtensa-lx106-elf-gcc --version
xtensa-lx106-elf-gcc (crosstool-NG esp-2020r3-49-gd5524c1) 8.4.0
now I think toolchain has been installed.
then
$ git clone https://github.com/micropython/micropython.git
$ cd ports/unix
$ make submodules
$ make
$ ./micropython, got it.
$ make test
801 tests performed (21040 individual testcases)
801 tests passed
then
cd ..
cd esp8266
$ make submodules
$ make V=1 submodules
Updating submodules: lib/axtls lib/berkeley-db-1.xx
git submodule update --init ../../lib/axtls ../../lib/berkeley-db-1.xx
$ make V=1
OK, IT SHOWS THE ERRORS:
xtensa-lx106-elf-gcc: error: unrecognized command line option '-mforce-l32'; did you mean '--force-link'?
File "../../py/makeqstrdefs.py", line 188, in <module>
preprocess()
File "../../py/makeqstrdefs.py", line 62, in preprocess
for output in p.imap(pp(flags), chunks):
File "/usr/lib/python3.8/multiprocessing/pool.py", line 868, in next
raise value
File "/usr/lib/python3.8/multiprocessing/pool.py", line 125, in worker
result = (True, func(*args, **kwds))
File "../../py/makeqstrdefs.py", line 46, in run
return subprocess.check_output(args.pp + flags + files)
File "/usr/lib/python3.8/subprocess.py", line 411, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "/usr/lib/python3.8/subprocess.py", line 512, in run
raise CalledProcessError(retcode, process.args,
subprocess.CalledProcessError: Command '['xtensa-lx106-elf-gcc', '-E', '-I../../lib/berkeley-db-1.xx/PORT/include', '-I.', '-I../..', '-Ibuild-GENERIC', '-I/usr/include', '-Wall', '-Wpointer-arith', '-Werror', '-std=gnu99', '-nostdlib', '-DUART_OS=-1', '-fsingle-precision-constant', '-Wdouble-promotion', '-D__ets__', '-DICACHE_FLASH', '-fno-inline-functions', '-Wl,-EL', '-mlongcalls', '-mtext-section-literals', '-mforce-l32', '-DLWIP_OPEN_SRC', '-DFFCONF_H="lib/oofatfs/ffconf.h"', '-DMICROPY_VFS_FAT=1', '-DMICROPY_VFS_LFS2=1', '-DLFS2_NO_MALLOC', '-DLFS2_NO_DEBUG', '-DLFS2_NO_WARN', '-DLFS2_NO_ERROR', '-DLFS2_NO_ASSERT', '-DMICROPY_PY_USSL=1', '-DMICROPY_SSL_AXTLS=1', '-I../../lib/axtls/ssl', '-I../../lib/axtls/crypto', '-I../../extmod/axtls-include', '-DMICROPY_PY_BTREE=1', '-Os', '-DNDEBUG', '-Iboards/GENERIC', '-fdata-sections', '-ffunction-sections', '-DMICROPY_MODULE_FROZEN_MPY', '-DMICROPY_QSTR_EXTRA_POOL=mp_qstr_frozen_const_pool', '-DMICROPY_MODULE_FROZEN_STR', '-DMICROPY_ROM_TEXT_COMPRESSION=1', '-DNO_QSTR', '../../lib/oofatfs/ff.c', '../../lib/oofatfs/ffunicode.c', '../../lib/littlefs/lfs2.c', '../../lib/littlefs/lfs2_util.c', '../../lib/axtls/ssl/asn1.c', '../../lib/axtls/ssl/loader.c', '../../lib/axtls/ssl/tls1.c', '../../lib/axtls/ssl/tls1_svr.c', '../../lib/axtls/ssl/tls1_clnt.c', '../../lib/axtls/ssl/x509.c', '../../lib/axtls/crypto/aes.c', '../../lib/axtls/crypto/bigint.c', '../../lib/axtls/crypto/crypto_misc.c', '../../lib/axtls/crypto/hmac.c', '../../lib/axtls/crypto/md5.c', '../../lib/axtls/crypto/rsa.c', '../../lib/axtls/crypto/sha1.c', '../../extmod/modbtree.c', '../../lib/berkeley-db-1.xx/btree/bt_close.c', '../../lib/berkeley-db-1.xx/btree/bt_conv.c', '../../lib/berkeley-db-1.xx/btree/bt_debug.c']' returned non-zero exit status 1.
make: *** [../../py/mkrules.mk:105: build-GENERIC/genhdr/qstr.i.last] Error 1
make: *** Deleting file 'build-GENERIC/genhdr/qstr.i.last'
It seems like toolchain's problem, but I've still tried the old way
$ make V=1 axtls
make: *** No rule to make target 'axlts'. Stop.
and I've tried
$ git submodule update --init
it doesn't work as well.
So, do I have to use esp-open-sdk as the toolchain in esp8266?
Those has been added into /etc/profile
export PATH=~/ESP/xtensa-lx106-elf-gcc8_4_0-esp-2020r3-linux-amd64/xtensa-lx106-elf/bin:$PATH
export IDF_PATH=~/ESP/esp8266/ESP8266_RTOS_SDK
export ESPIDF=~/ESP/esp8266/ESP8266_RTOS_SDK
export PATH=/home/kevin/micropython/micropython/ports/unix:$PATH
I'm totally confused now. SOS.
I've been crashed down by a compile issues in esp8266.
Re: I've been crashed down by a compile issues in esp8266.
I just want to tell you guys, I just try the toolchain from esp-open-sdk, version=4.8.x , now it's working for me, I will try to compile esp32 with the latest toolchain and the older one, later.
been tested. If you want to compile esp32, get your toolchain from there:
https://github.com/espressif/esp-idf
Hi kevinscorpionfox,kevinscorpionfox wrote: ↑Wed Jun 02, 2021 4:54 pmI just want to tell you guys, I just try the toolchain from esp-open-sdk, version=4.8.x , now it's working for me
I would like to use ESP8266_RTOS_SDK. Can you be more specific what you have done exactly. You mentioned some problems
Thanks,I'm totally confused now. SOS.
hcet14
I'm a beginner with this stuff and no programmer at all.
Dude, that's my "be more specific", DO NOT USE ESP8266_RTOS_SDK when you try to complie micropython project in ESP8266. I wasted couple days becasuse of this.hcet14 wrote: ↑Sun Jun 27, 2021 9:23 amHi kevinscorpionfox,kevinscorpionfox wrote: ↑Wed Jun 02, 2021 4:54 pmI just want to tell you guys, I just try the toolchain from esp-open-sdk, version=4.8.x , now it's working for me
I would like to use ESP8266_RTOS_SDK. Can you be more specific what you have done exactly. You mentioned some problemsThanks,I'm totally confused now. SOS.
hcet14
