New to MicroPython, putty showing garbage chars
Re: New to MicroPython, putty showing garbage chars
That is correct. You should not have to press anything. Only, if the terminal is unresponsive do I try the RESET button. If that doesn't work I unplug/plug.
ok i pressed reset button but it just shows the same thing
I'm having a similar issue.
Does the default MicroPython-xxxxx WiFi AP show up for you? Or is it just the REPL over serial that doesn't work?
My issue just resolved itself by using
option during flashing. Maybe this is the solution for you, too.
-fm dout
I'll try that, can you give me the full command just in case? Are you using an ESP8266?
Are you using this for flashing?
esptool.py --port /dev/ttyUSB0 --baud 460800 write_flash --flash_size=detect -fm dout 0 esp8266-20170108-v1.8.7.bin
Yes, I'm using a ESP8266 on a ESP-01S board. This is the thread I opened: viewtopic.php?f=16&t=10741 You can find some example commands there. For me, -fm dout made all the difference. Anything with worked as long as I used that option.
Did you check if your MicroPython-xxxxxx WiFi AP shows up and it's only the serial console that doesn't work?
Also, I think I'm using a different firmware: I have 1.16.
I tried the -dout and I'm still getting the same thing as before. I'm not able to access REPL using rshell
It installs the MicroPython fine, but it says 'No Micropython boards connected'
How are you connecting to ESP8266 after flashing? Are you using rshell?
I'm sorry that this didn't fix it for you.
I'm on Linux and I'm currently using screen. When connecting the USB adapter, I'm using dmesg to find out the device port.
dmesg -wH
screen /dev/ttyUSB0 115200
I also found out that my USB power isn't super stable. Did you try every USB port? Did you try with an external power source?
Also, after successfully flashing MicroPython, by default the AP_IF (access point network interface) is enabled and you should see a "MicroPython-xxxxxx" WiFi SSID! Just use your phone or something to check all the available WiFi networks. Doesn't have to do anything with the serial connection. But this way you can find out if MicroPython runs and it's only the serial connection that's faulty.
I'm on Linux (Raspberry Pi). I installed screen, and I'm connected to USB0, and when I run the command , I get a black screen , and when I press the reset button on the ESP8266, I don't get REPL, it says Mode : SoftAP
I'm not seeing the ESP8266XXX Wi-Fi either
