ImportError: no module named 'uasyncio'
snake77
Post by snake77 » Sun Jun 27, 2021 1:07 pm
When I try to import the module, I get:
>>> import uasyncio
It's also not listed when I call the help command that I found in the docs:
>>> help("modules")
__main__          inisetup          ucryptolib        usocket
_boot             lwip              uctypes           ussl
_onewire          machine           uerrno            ustruct
_webrepl          math              uhashlib          usys
apa102            micropython       uheapq            utime
btree             neopixel          uio               utimeq
builtins          network           ujson             uwebsocket
dht               ntptime           uos               uzlib
ds18x20           onewire           upip              webrepl
esp               port_diag         upip_utarfile     webrepl_setup
flashbdev         uarray            urandom           websocket_helper
framebuf          ubinascii         ure
gc                ucollections      uselect
Plus any modules on the filesystem
The ESP8266 has been flashed with the most recent firmware from the website:
esp8266-1m-20210618-v1.16.bin
I couldn't find any further information in the docs. :( I guess I need to install the module? But why is it not there already? The docs say it's part of MicroPython stdlib.
snake77
Re: ImportError: no module named 'uasyncio'
Post by snake77 » Sun Jun 27, 2021 1:49 pm
Okay, when I install it via upip, it works.
import upip
upip.install("uasyncio")
However, I still don't understand why this was necessary. It isn't mentioned anywhere. Did I overlook something?
Post by pythoncoder » Mon Jun 28, 2021 9:09 am
Something is wrong there. Recent versions (1.5, 1.6) of firmware include uasyncio V3. Please ensure you are running either V1.6 or a daily build. It's well worth ensuring you have V3 which fixes a lot of bugs. To check it do this at the REPL:
>>> import uasyncio
>>> uasyncio.__version__
(3, 0, 0)
snake77
Post by snake77 » Mon Jun 28, 2021 9:38 am
I connected via serial console, did a soft reboot with ^D and got the following output:
MPY: soft reboot
MicroPython v1.16 on 2021-06-18; ESP module (1M) with ESP8266
>>> import uasyncio
(3, 0, 0)
Note: This is the uasyncio from the lib folder, which was installed by upip. It was not automatically included.
kevinkk525
Post by kevinkk525 » Mon Jun 28, 2021 10:30 am
It's possible that the 1M still doesn't include the module uasyncio? It was not included earlier but I remember having had a discussion about it.
Kevin Köck
JennaSys
Post by JennaSys » Tue Jul 27, 2021 12:16 am
I just went through this myself, and can confirm that the 1M build does NOT include uasyncio by default. It can be added with a custom build though.
John Sheehan
