Page 2 of 4
Re: Won't wake up from Deep Sleep
Posted: Sun Jul 25, 2021 11:15 pm
by davef
I downloaded the D1 mini schematic and the part I was referring to is U2, a transistor-pair UMH3N. I don't know how the D1 mini is expected to boot-up when you use the USB. Are you running rshell?
You said you stopped using the CH340C, did you remove it from the board?
Posted: Sun Jul 25, 2021 11:46 pm
by dhust
Yeah, this is all confusing. I'm just annoyed by, what seems like, the inconsistencies in the system. I disconnect everything and programs won't upload or run like they used to. I just don't get it. So discouraging. What should have taken me a week has taken three weeks because of all of this.
Posted: Sun Jul 25, 2021 11:58 pm
by davef
I was hoping that knowing if you were using rshell and how you "stopped using the CH310" might provide more clues.
Posted: Mon Jul 26, 2021 12:06 am
by davef
Hmmm, I saw a message that said you had tried rshell, but it has disappeared.
I would focus on a standard un-modified board and rshell, at least to try and determine why rshell doesn't work.
Posted: Mon Jul 26, 2021 12:17 am
by dhust
davef wrote: ↑Mon Jul 26, 2021 12:06 am
I moved it to the Third Party Programs section, or whatever the name is. I have two new ESP-12F chips with a development board that I snap it into. I can't even do
on it.
This is what I get:
c:\Projects\ESPnow>esptool.py --port COM3 chip_id
esptool.py v3.0
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header
Posted: Mon Jul 26, 2021 12:31 am
by davef
Have you checked that you have a connection to COM3? How many different boards are you working on?
Posted: Mon Jul 26, 2021 12:34 am
by davef
I would often get the same. Don't know what fixed it, but haven't seen it for months.
Can you erase the chip?
Posted: Mon Jul 26, 2021 1:42 pm
by dhust
davef wrote: ↑Mon Jul 26, 2021 12:31 am
I'm using the port that showed up in Device Manager on Windows. This is a new board I've been working with while I try to figure out the other one we've been working on. Looks like the new one is even worse for me. Can't even flash it.
Posted: Mon Jul 26, 2021 1:53 pm
by dhust
davef wrote: ↑Mon Jul 26, 2021 12:34 am
No, I cannot erase it. Same thing happens. Here is the new chip and board I'm using that's been giving me this error. It's an ESP-12F.
Posted: Mon Jul 26, 2021 8:14 pm
by davef
Downloaded a ESP-12F datasheet but it is not the same PCB layout as yours. Who made your board? Have you got a Linux machine?
