# pollprob.py
import utime as time
import gc
import usocket as socket
import os
import ujson as json
#from loggerconfig import *
my_hostname = "ESP32test"
ACTIVITY_PIN = 2
BLINK_MS = 2000 # 2 seconds
# Globals
class Globals:
def __init__(self, poll_interval_ms) :
#print ("Globals: init")
self.poll_interval_ms = poll_interval_ms
self.poll_init ()
self.message_data = {}
self.states = {
'running' : True
def running (self) :
return self.states['running']
def shutdown (self) :
self.states['running'] = False
def poll_init (self) : # ???
self.poll_time_ms = time.ticks_ms ()
self.poll_time_next_ms = time.ticks_add (self.poll_time_ms, self.poll_interval_ms)
def poll_wait (self) :
#print ("Globals: ======> poll_wait:", time.time())
current_time_ms = time.ticks_ms ()
if time.ticks_diff (self.poll_time_next_ms, current_time_ms) <= 0 :
print ("Poll loop too much time")
self.poll_time_ms = current_time_ms
else :
#print ("Poll loop OK")
sleep_time_ms = self.poll_time_next_ms - current_time_ms
time.sleep_ms (sleep_time_ms)
self.poll_time_ms = self.poll_time_next_ms
def seconds_to_ms (self, interval_seconds) :
return interval_seconds * 1000
def minutes_to_ms (self, interval_minutes) :
return self.seconds_to_ms (interval_minutes) * 60
def hours_to_ms (self, interval_hours) :
return self.minutes_to_ms (interval_hours) * 60
def active_next_ms (self, interval_ms) :
return time.ticks_add (self.poll_time_ms, interval_ms)
def active_now (self, next_active_ms) :
return time.ticks_diff (self.poll_time_ms, next_active_ms) >= 0
def message_set (self, mess_id, mess_dict) :
if not mess_id in self.message_data :
self.message_data[mess_id] = mess_dict
else :
for mess_key in mess_dict :
self.message_data[mess_id][mess_key] = mess_dict[mess_key]
def message_get (self, mess_id) :
if mess_id in self.message_data :
return (self.message_data[mess_id])
else :
return {}
# end Globals
# GetCommand
class GetCommand:
def __init__(self, global_data) :
#print ("GetCommand: init")
self.global_data = global_data
self.s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
self.my_ip = network.WLAN().ifconfig()[0]
#print (self.my_ip)
self.address = socket.getaddrinfo(self.my_ip, 5010)[0][-1]
self.address = ("", 5010)
#print ("addr:", self.address)
self.s.bind(self.address)
self.s.settimeout(0)
def poll_it (self) :
#print ("GetCommand: poll_it")
while True :
try :
mess_address = self.s.recvfrom (2000)
print ("GetC:", mess_address)
message = mess_address[0]
address_port = mess_address [1]
#request_json = message.decode(encoding="ascii", errors="ignore")
request_json = message.decode ()
request_dict = json.loads (request_json)
#print ("Cmd:", request_dict)
except OSError :
#print ("GetC: no data")
return
# test for incomming messages
# Heartbeat
class Heartbeat:
#print ("Heartbeat: init")
# Respond to 'poll_it' every 15 seconds
self.active_interval_ms = self.global_data.seconds_to_ms (15) # activity milliseconds
self.active_next_ms = self.global_data.active_next_ms (0) # Send 1st message now
self.client_sender_socket = socket.socket (socket.AF_INET, socket.SOCK_DGRAM)
self.serial_number = 0
global my_hostname
#print ("Heartbeat: poll_it")
if not global_data.active_now (self.active_next_ms) :
return
self.active_next_ms = self.global_data.active_next_ms (self.active_interval_ms)
##### TEST!!!!!!!
self.serial_number += 1
action = 'heartbeat'
heartbeat_dict = {
'action' : action ,
'id' : my_hostname ,
action : {}
heartbeat_dict [action]['machine'] = {
"serial_number" : self.serial_number ,
"freq" : machine.freq () ,
"gc_mem_alloc": gc.mem_alloc () ,
"gc_mem_free": gc.mem_free ()
result_json = json.dumps (heartbeat_dict) # dictionary to json
bytesToSend = str.encode (result_json) # message length
print ("Sending to:", ('127.0.0.1', 5010))
self.client_sender_socket.sendto (bytesToSend, ('127.0.0.1', 5010))
# end Heartbeat #
# main
global_data = Globals (250) # 0.25 second poll interval
get_command = GetCommand (global_data)
heartbeat = Heartbeat (global_data)
#---- Poll loop
while global_data.running () :
#blink_status_led.poll_it ()
get_command.poll_it ()
#send_status.poll_it ()
heartbeat.poll_it ()
global_data.poll_wait ()
For testing the heartbeat instance sends a UDP message to 5010 on localhost. Normally the message would be sent to an external server.
The get_command instance should receive the UPD message(s) and display it. The recvfrom timeout is set to zero to prevent blocking
The ESP8266 board never receives the UDP message displaying:
Sending to: ('127.0.0.1', 5010)
[200~Sending to: ('127.0.0.1', 5010)
GetC: (b'{"heartbeat": {"machine": {"gc_mem_free": 101616, "serial_number": 1, "freq": 160000000, "gc_mem_alloc": 9552}}, "id": "ESP32test", "action": "heartbeat"}', ('127.0.0.1', 52539))
GetC: (b'{"heartbeat": {"machine": {"gc_mem_free": 76096, "serial_number": 2, "freq": 160000000, "gc_mem_alloc": 35072}}, "id": "ESP32test", "action": "heartbeat"}', ('127.0.0.1', 52539))
Thanks for your help,
Curt
