1MB Firmware on ESP-01S
Posted: Thu Oct 28, 2021 2:43 am
PREFACE
I was finally able to flash microPython on to an ESP-01S using the Thonny IDE. Curiously, although the ESP-01S has 1MB of Flash, I could not susccessfully flash the 512KB version of the firmware. After trying several variations of installing the 512KB version it kept generating an error at startup. However, as soon as I flashed the 1MB version it started in the IDE without out issue. My thought was if I could get the 512KB version to run, I would have more memory space for an application. I would appreciate any thoughts as to why the 512KB version installation failed to run.
QUESTION
Given that the 1MB firmware is the only one that appears to function properly; does anyone know how much memory space is available for an actual application?
Thanks, Mickey
QUESTION
Thanks, Mickey
