ESP8266 UART workaround
pytango
Post by pytango » Thu Oct 28, 2021 10:07 am
Hi Everyone!
I'm not strong in MicroPython and MCU programming so I'd like to get some suggestions and reviews from more experienced people how to work with another devices by UART and keep REPL. Or just maybe my experience bellow will help somebody.
I know that this question is very popular, but I haven't found the universal and completed solution.
In my case I'm setting communication between ESP8266 NodeMCU Lolin and GSM module SIM800L
Firstly I implemented first version of UART workaround based on detaching REPL from UART0 before read/write and reattach after, as it explained in MicroPython documentation for ESP8266.
import uos
class UartEsp8266:
    Class purposed to use UART with ESP8266 with REPL
    UART_ID = 0  # We always use UART0 because UART1 is write only on ESP8266 MCU
    def __init__(self, **kwargs):
        self.uart = machine.UART(
            self.UART_ID
        self.uart.init(
            **kwargs
    def read(self):
        Detach REPL from UART0, read and then reattach REPL to UART#0
        self.__detach_repl()
        data = self.uart.read()
        self.__reattach_repl()
        return data
    def write(self, data):
        Detach REPL from UART0, write bytes and then reattach REPL to UART0
        result = self.uart.write(data)
        return result
    def execute(self, cmd):
        Detach REPL from UART0, write command,
        wait and read response and reattach REPL to UART0
        return command response
        _write_result = self.uart.write(cmd)
        # TODO: add check of _write_result
        response = self.uart.read()
        return response
    def __reattach_repl(self):
        Reattach REPL to UART0
        uos.dupterm(self.uart, 1)
    @staticmethod
    def __detach_repl():
        uos.dupterm(None, 1)
But then I realised that all debug messages which I want to send to REPL will be sent to UART device too. Am I right or not?
And the idea came into my mind. I thought that we can use UART0 RX to read data from UART device, but send data through UART1 TX. In this approach we can send clean data to connected peripheral device, without "garbage" from REPL.
So I implemented second UART workaround prototype. I'm not sure is it good approach or not? What cons?
import uos
class UartEsp8266Hack:
    Class purposed to use UART with ESP8266 with REPL.
    This implementation uses RX from UART0 and TX from UART1
    UART_RX = 0
    UART_TX = 1
        self.uart_rx = machine.UART(
            self.UART_RX
        self.uart_rx.init(
            **kwargs
        self.uart_tx = machine.UART(
            self.UART_TX
        self.uart_tx.init(
            **kwargs
    def read(self):
        Detach REPL from UART0, read and then reattach REPL to UART0
        data = self.uart_rx.read()
        return data
        Just write data to UART1
        result = self.uart_tx.write(data)
        return result
        Write command to UART1,
        detach REPL from UART0,
        _write_result = self.uart_tx.write(cmd)
        response = self.read()
        return response
        uos.dupterm(self.uart_rx, 1)
    @staticmethod
Thanks for your advices!
