esp8266 data logger stand alone
Re: esp8266 data logger stand alone
Sure. That's what I asked initially. The deep sleep time does not count. So if your device is active for only 1 minute in a 15 minute cycle, the total energy needed is 15 times less, only 2400 mAh. That was my initial assumption. If the wake time is even shorter, the better.
the point of the access point working
as in any time you can access the device to check the current temperature
without any processing for final report
as every read taken by the device is recorded and update the access point web page
the wake time will be 1 second as maxRoberthh wrote: ↑Tue Nov 02, 2021 8:56 pmSure. That's what I asked initially. The deep sleep time does not count. So if your device is active for only 1 minute in a 15 minute cycle, the total energy needed is 15 times less, only 2400 mAh. That was my initial assumption. If the wake time is even shorter, the better.
the device just wake up take new reading and update all system file
and go sleeping again
So, every 15 minutes you take a new temperature reading, send it to the local end, go into esp.sleep_type(SLEEP_LIGHT), log it and display at the local end. And you can just use a socket connection, both in sta-mode.
almost what you say is correct
the local end is saved in the device it self
so that the access point will be required to access this index.html
and my server is build based on scoket connection
You can try esp.deepsleep() time in us? 15 minutes is a lot of microseconds!
OK you want to serve up a webpage. What are you going to display that on?
A PC or ?
any device have wifi
pc , mobile , tablet ....
An ESP8266 with a SSD1306 display?
