# MQTT Subscribe
# By: Nick Sebring
# 11-20-2021
# *****IMPORT NECESSARY MODULES******** #
# *****CONNECT TO NETWORK************** #
wlan.connect('YOUR_SSID', 'YOUR_PASSWORD')
wlan.active(True)
time.sleep(2) # GIVES IT TIME TO CONNECT
# *****LOOP UNTIL CONNECTED*********** #
while not wlan.isconnected():
print("Connecting to wifi ...")
time.sleep(2) # GIVE IT TIME TO CONNECT
print("Connected to WiFi")
print('network config:', wlan.ifconfig()) # PRINTS OUT THE IPCONFIG DATA
# *****ASSIGN VARIABLES*****************#
led = machine.Pin(13, machine.Pin.OUT) # ASSIGN OBJECT NAME TO PIN#, OBJECT IS AN OUTPUT.
# blue onboard LED on the ESP8266= Pin(2)
led(0) # TURN OFF LED AT STARTUP
topic = "LED" # MQTT TOPIC SUCH AS: upstairs/hallway/light. HERE WE JUST NAMED IT "LED"
message = ""
# True when new message is received in callback
new = False
# DEFINE CALLBACK TO KEEP CHECKING FOR NEW MESSAGES
def MQTT_callback(topic, msg):
global new
global message
print("received: ",topic,msg)
message = msg
new = True
# GIVE CLIENT A PROPER NAME, INTRODUCE CLIENT TO MQTT BROKER
SERVER = "192.168.1.13"
client = MQTTClient("ESP8266", SERVER) # EACH CLIENT MUST HAVE A UNIQUE "NAME/ID"
# NAME CAN BE SOMETHING LIKE "ESP_SENSOR_2"
# CONNECT CLIENT TO MQTT BROKER
client.connect()
print(client.connect())
client.set_callback(MQTT_callback)
client.subscribe(topic)
print("Connected to MQTT Server and subscribed to: ", topic)
mqtt = True
except:
print("MQTT connect failed")
mqtt = False
# LOOP IF WIFI AND MQTT CONNECTION WAS SUCCESSFUL
while wlan.isconnected() and mqtt:
client.check_msg()
if new:
print("New message: ",message)
led(int(message)) # TELL OBJECT "led", (int EXPECT A NUMBER, (message: 0=OFF, 1=ON))
new = False
except:
print("Client check failed ...")
time.sleep(1)
print("Wifi disconnected or MQTT could not connect")
