Hi...
I'm using a WEMOS D1 mini flashed with a fresh v1.17.
Starting my progam in the main.py using an import command fails in starting it after power up. After pressing the RESET button everything works fine. Any suggestions???
Thanx a lot,
chris
main.py does'n start...
Re: main.py does'n start...
What does your device perform in boot.py? If boot.py fails, main.py will not run. So maybe there is something in boot.py (or main.py) which needs some time after power on to settle.
okay, I will check... thanx!
