WiFi Fixed Channel parameter
Does microPython support the specification of a fixed WiFi channel when connecting?
For example, as a parameter in "station.connect('SSID', 'Pass', 'channel-number')", or in some other microPython network setting.
Re: WiFi Fixed Channel parameter
# Set WiFi access point name (formally known as ESSID) and WiFi channel
ap.config(essid='My AP', channel=11)
This appears to be setting the channel when the unit is used as an access-point.
Would that apply to a unit that's being configured as a station (AKA client)?
In other words:
If
station = network.WLAN(network.STA_IF)
iIs there a
station.config(channel=11).
In other words:
If
iIs there a
I have the answer; it doesn't work.
I inserted station.config(channel=11) into my code right after the creation of the station object; then ran the code. microPython thru an error saying 'requires AP'
If there's a way to set a station channel so it doesn't scan all channels when connecting, that 's not the way.
For a station, a logical place to put it would be as a parameter in the "connect' method.
I can understand not having the facility to set station channels to a fixed number; if for some reason the AP (router) channel is changed all the clients would stop connecting. However, the capability should allow clients to connect faster coming out of deep-sleep.
An interesting comment:
https://micropython-glenn20.readthedocs ... -operation
This seems to imply if you use a ESPNow image that you could set the station channel.Some versions of the ESP IDF don’t permit setting the channel of the STA_IF at all, other than by connecting to an Access Point (This seems to be fixed in IDF 4+). Micropython versions without the ESPNow patches also disallow setting the channel of the STA_IF.
WOW, just when you thought using microPython was confusing enough - lol
You're right, they clearly show a coding example:
Thanks, looks like this may work.
By the way I'm also using umqtt for microPython, if you're familiar with MQTT, Node-RED and Node.js you can setup a network between devices very quickly.
The only thing is there are two distributions umqtt.simple and umqtt.robust. umqtt.simple only supports QoS (Quality of Service) levels 0 & 1, not 2. It's my understanding that umqtt.robust adds functionality to umqtt.simple (you need to install both distributions).
If you have any knowledge of umqtt, does umqtt.robust support QoS level 2?
I don't understand why they don't have a single distribution, or at least various distribution levels with clearly labelled feature extensions.w0 = network.WLAN(network.STA_IF)
w0.active(True) # Set channel will fail unless Active
w0.config(channel=6)
My understanding is that there is quite a bit of work porting Micropython to all the different hardware platforms and that some features are just not available on various platforms. For example ESPNow, ESPMesh and probably others that I don't even know about.
So, it takes keen individuals to exploit these added features. Check out the ESPNow thread.
I know very little about umqqt and have never used it.
I'll definitely be checking-out the ESPNow thread; that looks like a great find - thanks.
As far as MQTT, and Node-RED, if you're interested, checkout these sites (BTW both technologies were created by IBM in the 1990's, but their use is exploding now)
Node-RED Essentials https://www.youtube.com/playlist?list=P ... qFcXBkHy-6
MQTT Essentials https://www.hivemq.com/mqtt-essentials/
Curiously, even though IBM developed MQTT & Node-RED they didn't integrate them; here's a link that will show how to integrate MQTT into Node-RED: http://stevesnoderedguide.com/install-m ... r-node-red
Have fun
Have fun
I'll check out the links when I get back to civilization and unlimited data.
I had a good play with Hologram a few years ago but my home automation system running on ESP32s using uMail and Gmail's SMTP server works well enough through a cell connection.
I use ESPNow in a remote water tank monitoring system, so keep up to date on that development.
