You've created an Access-Point object not a station object; that has always worked even in the standard build.w0 = network.WLAN(network.AP_IF)
Remember this excerpt from the example [https://micropython-glenn20.readthedocs ... -operation] you provided on 16-Dec:
w0 = network.WLAN(network.STA_IF)
w0.active(True) # Set channel will fail unless Active
w0.config(channel=6)
This is what hasn't worked for the ESP8266 in the standard or ESPNow builds.
Note the error when trying to create a station object:
File "main.py", line 18, in
OSError: AP required
