Dim Neopixel rings more than np = (1,1,1)
damada
Post by damada » Tue Dec 21, 2021 9:10 am
Dear forum,
I've built a simple NTP clock with two Neopixel rings using the highlevel neopixel module on an ESP8266 with OLED display (NodeMCU ESP-12F).
The clock is meant as a night clock, but unfortunately, the LED strips are very bright. Even at lowest color brightness, they are still too much of a lamp:
import neopixel
np_o = neopixel.NeoPixel(machine.Pin(0), 60)  # D3
np_i = neopixel.NeoPixel(machine.Pin(14), 24)  # D5
for i in range(np_o.n):
    np_o[i] = (1,1,1)
    np_o.write()
for i in range(np_i.n):
    np_i[i] = (1,1,1)
    np_i.write()
Half the brightness would be good, or even a third.
Is it possible to further reduce the brightness by PWM? How would I combine this with the neopixel module?
Thanks in advance
Daniel
Re: Dim Neopixel rings more than np = (1,1,1)
Post by Roberthh » Fri Dec 24, 2021 1:12 pm
You could try switch between a (1,1,1) (on) setting and a (0,0,0) (off) setting in a PWM fashion. Short time on, long time off. If that is done sufficiently fast, more then 25 times per second, then there should be no visible flicker.
damada
Post by damada » Tue Jan 18, 2022 1:09 pm
Dear Robert,
sorry for the late reply!
Your approach works, but only up to approx. 20Hz or so. There is considerable flicker, or at least the brightness varies considerably.
Speaking with my wife, she prefers the brighter clock rather than the flickering clock :)
damada
Post by damada » Wed Jan 19, 2022 7:52 am
Just for completeness, here is what I tried:
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import neopixel
import esp
import utime as time
#np_o = neopixel.NeoPixel(Pin(5), 60)  # D1 !!! NOK !!!
#np_i = neopixel.NeoPixel(Pin(4), 24)  # D2 !!! NOK !!!
#np_i = neopixel.NeoPixel(Pin(2), 24)  # D4 !!! startup blink !!!
np_o = neopixel.NeoPixel( Pin(0), 60)  # D3
np_i = neopixel.NeoPixel(Pin(14), 24)  # D5
for _ in range(np_o.n):
    np_o[_] = (0,0,0)
    np_o.write()
for _ in range(np_i.n):
    np_i[_] = (0,0,0)
    np_i.write()
https://forum.micropython.org/viewtopic.php?f=16&t=11670
def freq_test1():
    for freq in (25, 50, 60, 100):  # Hz
        print("\n>>>>> %i Hz ..." % freq)
        period = 1./freq  # s
        period *= 1000  # ms
        for dutyfactor in (1,2,3,4,5):
            print("\n  >> 1/%i" % dutyfactor)
            time_on = period/(dutyfactor+1)
            time_off = period/(dutyfactor+1) * dutyfactor
            ts_start = time.time()
            while time.time() - ts_start < 3:
                ## 1) single pixel
                np_i[0] = (0,0,0)
                ## 2) all pixels
                    np_i[i] = (0,0,0)
                ## 1)+2)
                np_i.write()
                time.sleep_ms(int(time_off))
                ## 1) single pixel
                np_i[0] = (1,1,1)
                ## 2) all pixels
                    np_i[i] = (1,1,1)
                ## 1)+2)
                np_i.write()
                time.sleep_ms(int(time_on))
            time.sleep_ms(1000)
freq_test1()
https://github.com/Achimh3011/micropython/blob/master/esp8266/modules/neopixel.py
https://docs.micropython.org/en/latest/esp8266/quickref.html#neopixel-driver
pin = Pin(14, Pin.OUT)
is800khz = True
bpp = 3
n = 24
buf0 = bytearray(n * bpp)
buf1 = bytearray((1,1,1) * n)
def freq_test2():
    for freq in (10, 25, 50, 60, 100, 200):  # Hz
        period *= 1000  # ms
                esp.neopixel_write(pin, buf0, is800khz)
                esp.neopixel_write(pin, buf1, is800khz)
            time.sleep_ms(1000)
freq_test2()
print('\n>>>> Ready.')
