Can't build the ESP8266 port
gscofano
Post by gscofano » Wed Dec 22, 2021 4:55 am
Greetings,
I need to load a Python module in a Wemos ESP8266 wi-fi board with 4kB of Flash. The module in question is Tronpy. I'm facing some memory allocation errors and, reading https://docs.micropython.org/en/latest/ ... kages.html, I understood that I should compile my module into bytecode. Such procedure would shrink the module size, making it easier to fit inside my device. I understand that, in order to do that, I need mpy-cross and the ESP8266 port.
I downloaded the micropython-1.17 source code from Github and I'm following the instructions on the README files. I understood that the first thing I should do was to compile mpy-cross. So I entered the comands:
cd mpy-cross/
make
mpy-cross was compiled without problems.
My next step was to compile ports/esp8266. According to the README.md file in such directory, the recomnended approach was to use a docker image. On the root directory of the project, I entered the following commands:
docker run --rm -v $HOME:$HOME -u $UID -w $PWD larsks/esp-open-sdk make -C ports/esp8266 submodules
After this, I'm getting the following error messages:
make: Entering directory '/home/gscofano/Documentos/dev/micropython/micropython-1.17_2/ports/esp8266'
make: stat: Makefile: Permission denied
make: *** No rule to make target 'submodules'.  Stop.
make: Leaving directory '/home/gscofano/Documentos/dev/micropython/micropython-1.17_2/ports/esp8266'
My docker seems to be correctly configured. When I issue
 docker run hello-world
docker sends me a message indicating that it was able to connect to the image from the Docker Hub ("Hello from Docker! This message shows that your installation appears to be working correctly. etc.")
I belive I followed all the instructions on the README files correctly. What could I possibly be missing? Is there any easier way to load a module in Micropython?
Thank you very much in advance.
wr300000
Re: Can't build the ESP8266 port
Post by wr300000 » Sat Feb 26, 2022 2:15 pm
Try this from jimmo
viewtopic.php?f=15&t=7136#p40603
BTW, It's working on amd64 CPU
