urequests - Error sending to Telegram bot
Frank
Post by Frank » Sat Jan 15, 2022 6:21 pm
I've only recently gotten into ESPs and Micropython.
I want to send a message from ESP8266 (D1 Mini V3 NodeMCU ESP8266EX) to Telegram bot.
import urequests
urequests.post("https://api.telegram.org/bot" + botToken + "/sendMessage?chat_id=" + str(chatId) + "&text=" + text)
Sending the message with the ESP32 is successful.
The ESP8288 comes with the following error message:
File "<stdin>", line 17, in <module>
File "urequests.py", line 120, in post
File "urequests.py", line 62, in request
OSError: -40
Is there a solution for this problem or can't I send to the bot with esp8266?
user_pico1
Re: urequests - Error sending to Telegram bot
Post by user_pico1 » Sat May 28, 2022 3:51 pm
import urequests
OSError: -40
I have the same problem on Raspberry pi pico. Have you already solved it? Or could anyone help?
I can send requests to other sites, but it is not working with telergam.
KJM
Post by KJM » Sun May 29, 2022 12:09 am
What happens if you substitute http for https ?
user_pico1
Post by user_pico1 » Sun May 29, 2022 2:53 pm
In this case error "Redirects not yet supported"
But I have no problem with sending requests on https google.
KJM
Post by KJM » Mon May 30, 2022 6:36 am
sadly urequests can't handle redirects and there is no ussl in upython for the 8286
