serial communication and variables
mak_paint
Re: serial communication and variables
Post by mak_paint » Fri Feb 04, 2022 1:13 am
The code doesn't work, I suspect because of the UART communication so I tried this little code and it doesn't work
serial = UART(0, 115200)
serial.init(115200, bits=8, parity=None, stop=1)
ch = ""
    if serial.any() > 0:
        ch = serial.readline()
        if ch == "on":
            serial.write("led on")
            led.on()
        elif ch == "off":
            serial.write("led off")
            led.off()
            serial.write(ch)
Shards
Post by Shards » Fri Feb 04, 2022 10:48 am
Your basic problem is that UART 0 is used by the REPL see: https://docs.micropython.org/en/latest/ ... serial-bus in the standard documentation for the ESP8266 port.
OlivierLenoir
Post by OlivierLenoir » Fri Feb 04, 2022 4:07 pm
mak_paint wrote:
Thu Feb 03, 2022 10:01 pm
OlivierLenoir wrote:
Sat Jan 29, 2022 9:17 am
If the list of color is very long, I recommend using a json file outside of your code.
hello, I'm a bit confused about what you mean when you tell me to use json outside the code
Create a json file name it cars.json and write the following json structure in it. Documentation is here
{"ford": {"ranger_2011_2016": [0, 1, 0, 1, 0, 1], "explorer_2008_2012": [0, 1, 0, 1, 0, 1], "fiesta_2006": [0, 1, 0, 1, 0, 1], "fiesta_2006_2010": [0, 1, 0, 1, 0, 1]}, "chevrolet": {"aveo_2008_2012": [0, 1, 0, 1, 0, 1], "corsa_2005": [0, 1, 0, 1, 0, 1], "corsa_2006_2010": [0, 1, 0, 1, 0, 1], "corsa_2011_2016": [0, 1, 0, 1, 0, 1]}}
You can access json data like that.
from json import load
DATA_JSON = 'cars.json'
with open(DATA_JSON) as _json:
    cars = load(_json)
mak_paint
Post by mak_paint » Fri Feb 04, 2022 6:07 pm
yes but, this car.json document is inside the microcontoler?.. because if that is the case, I don't see the advantage regarding the use of a dictionary, now if the car.json file comes via serial it would be difficult because remember that what is going to communicate with the esp8266 via serial is going to be a a touch screen, which will be the user interface and I simply want it to send the make and model of the car to the microcontroller to search for and place in the function
mak_paint
Post by mak_paint » Fri Feb 04, 2022 6:34 pm
ok so far what I have done is enter the boot.py file of the micro and uncomment this line (uos.dupterm(None, 1) ), then I restart the micro and open the serial communication of the arduino IDE and there I try (it is annoying because then I have to flash the microcontroller to be able to continue in the code)... however, it does communicate because if you look at the last line of code I ask that everything that is received by serial be printed again, and it does, but I can't get the led to turn on because it never enters that conditional.
then i tried this and it works but notice how i put the ch variant
from machine import Pin, UART
led = Pin(5, Pin.OUT)
ch = b""
        if ch == b"on":
            led.on()
        elif ch == b"off":
            led.off()
            serial.write(ch)
OlivierLenoir
Post by OlivierLenoir » Fri Feb 04, 2022 8:51 pm
Yes the json file is in the micro-controller and it's a good practice to separate data from code.
