I've created a simple microPython client that publishes a message to a topic; the subscribing client acknowledges the receipt of the message. The acknowledgement is processed by the uPy client.
I'm curious as to how the Callback function in microPython functions; does is use interrupts, or is there a built-in loop in the publish method that waits for a callback (if set) after it sends the message?
microPython MQTT Callback implementation
Re: microPython MQTT Callback implementation
I've found the answer to my own question regarding callback implementation.
Thanks anyway, MM
Thanks anyway, MM
