Input Pin.value() always zero unless pin switched on.
Posted: Wed May 18, 2022 5:21 am
Hi there,
just not shure if this is normal behaviour.. that's why i ask here before running an issue
I just loaded a fresh copy of v1.18 on a d1mini.
My goal is to build a simple remote control for my robots and.. it didn't work as expected.
My plan is to use pin irqs to send the pins number via socket connection but my pins were deaf.
So I wrote a little test.. which didn't work, too:
I played with a single pin, too and sometimes, it worked.. Finally I found out that I had to switch each pin on befor it really reads a value.
After re-writing my test like this:
It worked... But why?
Maybe, pin creation misses some pin initialization? or is this normal behaviour?
Edit: Just in case... here are my files https://gitlab.com/rapp.jens/mp-robot-remote
pins = [Pin(x,Pin.IN|Pin.PULL_UP) for x in [14,12,13,15,4,5]]
for pin in pins:
pin.irq(lambda p: print (p))
for pin in pins:
# I just added this line
pin.on()
