I spent a lot of time to make work this stuff without any success.
https://www.amazon.fr/XTVTX-d%C3%A9velo ... 093GR7MJM/
My main problem is that I can't get a clean connection to the device after uploaded the firmware with the command:
picocom /dev/ttyUSB0 -b115200
After when I quit picocom and restart it again I get this:
(venv) home@home ~/projects/esptool $ picocom /dev/ttyUSB0 -b115200
picocom v2.2
port is : /dev/ttyUSB0
flowcontrol : none
baudrate is : 115200
parity is : none
databits are : 8
stopbits are : 1
escape is : C-a
local echo is : no
noinit is : no
noreset is : no
nolock is : no
send_cmd is : sz -vv
receive_cmd is : rz -vv -E
imap is :
omap is :
emap is : crcrlf,delbs,
Type [C-a] [C-h] to see available commands
Terminal ready
When I continue restart picocom again, I get nearly the same result, but without >>> anymore.
When I press reset, or I unplug and plug the device nothing special changes.
So what have been tryed:
esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash -fm qout --flash_size=4MB 0 esp8266-20220117-v1.18.bin
I also tryed to let esptool to find alone the flash_size, no results
I tried also some other firmwares:
esp8266-1m-20220117-v1.18.bin
esp8266-20170108-v1.8.7.bin
esp8266-512k-20220117-v1.18.bin
I also tryed to install
picocom 3.1 and connect with... No results neither
I tried to connect to it with putty, No results
I tried to connect to it with screen command, No results
I have tryed on another board of the same serie, No results
I am working on ubuntu 18.04, and my python version is python3.6
The very best part is that on an other computer I tried to connect to it with the Arduino IDE, with the serial monitor, and this way it works "perfectly"
I was able to make an esp.check_fw() wich returned True.
Other interesting point, when this board is flashed I can see it's WiFi Access Point Microphython-xxxxx.
Mean the firmware is running nearly good... So where can be the problem? Any advices are very wellcome =)
some logs of erasing and flashing commands:
(venv) home@home ~/projects/esptool $ esptool.py --port /dev/ttyUSB0 erase_flash
esptool.py v3.3.1
Serial port /dev/ttyUSB0
Connecting....
Detecting chip type... Unsupported detection protocol, switching and trying again...
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: 40:91:51:52:ae:ea
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 17.9s
Hard resetting via RTS pin...
(venv) home@home ~/projects/esptool $ esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash -fm dio --flash_size=4MB 0 esp8266-20220117-v1.18.bin
esptool.py v3.3.1
Connecting....
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash will be erased from 0x00000000 to 0x0009bfff...
Flash params set to 0x0240
Compressed 635992 bytes to 418428...
Wrote 635992 bytes (418428 compressed) at 0x00000000 in 37.1 seconds (effective 137.0 kbit/s)...
Hash of data verified.
Leaving...
