Initially (still on micropotchon 1.17) I had a problem with the SD card, in order to re-mount it, I had to reboot the board. This is very strange, because I unmount the sd card when my code was completed.
import machine, os
sd = machine.SDCard(slot=2)
os.mount(sd, "/sd")
1) When i opening any file: E (19210) sdmmc_cmd: sdmmc_write_sectors_dma: sdmmc_send_cmd returned 0x108
2) When i get card info by
sd.info()
3) When i mounting SD without reboot: (-259, 'ESP_ERR_INVALID_STATE') or OSError: 16 Note: SD Card unmounting always.
The saddest part is that it doesn't happen every time. Sometimes it still works and I have this problem on 3 different boards.
List of boards on which the problem is observed:
- LILYGO® TTGO T-Camera Plus ESP32-DOWDQ6 : http://www.lilygo.cn/prod_view.aspx?Typ ... t3:50067:3
- LILYGO® TTGO VGA32 V1.4 : http://www.lilygo.cn/prod_view.aspx?Typ ... t3:50063:3
- Goouuu ESP32F Dev Kit : https://prnt.sc/yddtje - pinout
PS The card has a size of 1 GB, and it was additionally checked on arduino through an additional module, where it always worked properly. From the computer, there are no problems with the SD card either.
