REPL Prompt very slow
mike1098
Post by mike1098 » Tue Jul 05, 2022 9:26 am
First let me say many thanks to all contributors of micropython. It helps me a lot to develop code for MCUs.
I developed my project on a LUA NodeMCU and now I want to transfer the code to a Espressif ESP-WROOM-02 ESP8266 to have a smaller form factor.
It was possible to install micropython on the ESP-WROOM-02 without any problem. I first cleared the flash and then transferred the firmware. So far that looked OK but if I access REPL its very slow and didnt accept some characters or even swallow them. With copy paste it works somehow but not so usable to test things like wifi connection or GPIOs.
Anyone an idea why REPL doesnt work on the ESP-WROOM-02 board?
Any help is much appreciated.
regards
Michael
KJM
Re: REPL Prompt very slow
Post by KJM » Wed Jul 06, 2022 12:27 am
What ide you using Michael? I've used the 8286 on Thonny, uPyCraft & Atom & always found the repl fairly fast.
Post by jimmo » Wed Jul 06, 2022 2:23 am
That's just the module right? What did you use to connect to the UART? (i.e. FTDI etc?)
mike1098
Post by mike1098 » Thu Jul 07, 2022 8:20 am
I use 'screen /dev/ttyUSB0 115200' and for development https://tinkerdoodle.cc on both same issue.
In Thonny I got a timeout:
raise TimeoutError("Reaction timeout. Bytes read: %s" % self._read_buffer)
TimeoutError: Reaction timeout. Bytes read: bytearray(b'')
The TTL converter use a ch341-uart chip. The NodeMCU is using the same chip and this board is working with Thonny very well.
Michael
mike1098
Post by mike1098 » Thu Jul 07, 2022 3:57 pm
I did a couple of tests with Arduino IDE and also having issue there. Upload of code sketch works well but serial communication even with lower baud rate is not stable.
I am currently using power from the TTL converter and suspect that maybe its not strong enough for runtime. I will test later with a reliable power source.
Thank you
Michael
mike1098
Post by mike1098 » Thu Jul 07, 2022 6:51 pm
After connecting a "real" power source all works fine.
Thank you and sorry to bother you for nothing.
regards
Michael
